McGrandpa opened this issue on Nov 03, 2020 ยท 56 posts
McGrandpa posted Tue, 03 November 2020 at 3:35 AM
NO python works unless it came WITH P12 - that is a baaad booger, if not fixed very soon, refund. Especially since y'all refuse to allow Poser to directly load DAZ content (as in FIGURES!) Material Room - Assignment Tab is a rude joke so far. If it even works it is so vastly different from the familiar "Simple View" tab there is no figuring it out without the reference manual. Color - in the Pose Room "Main View" controls vanished, no clues where they went, and the very confused "Object Style" seems to be the only way to adjust the appearance at all. CONSTRUCT - needs removal until its adjustable again.
Am I actually TRYING to use this stuff, with a Figure, a Scene, and RENDERING? HELL YES !!
My 66th Birthday PC Build (July 1, 2020) : named BadMoonRYZEN!, W10Pro x64, Octal Core RYZEN7 X3700 4.05 GHz, 64GB DDR4 RAM, GeForce RTX 3060 - 12GB GDDR6, PP2014, PP 11, P12, PS-CS4 Extended & Vue 2024.
McG.
McGrandpa posted Tue, 03 November 2020 at 3:37 AM
So Far the ONE Positive thing 12 has over P8 IS: The Library works.
McG.
McGrandpa posted Tue, 03 November 2020 at 3:43 AM
ACCORDING TO the Poser Manual, POST Effects are used ONLY with SuperFLY. I am NOT using SuperFLY, just FireFly. And POST Effects ARE BEING APPLIED AND I CANNOT STOP IT!!!!
McG.
McGrandpa posted Tue, 03 November 2020 at 4:20 AM
no, nope this is not acceptable. Either explain how to STOP this damn post lighting crap or I will take my refund today.
McG.
Liquid_Ice posted Tue, 03 November 2020 at 4:40 AM
Please relax there a bit. Everybody who've read the fora knew not all scripts would work. They are working on it.
Remember you have an early version. They are still ironing out the kinks and whatnot.
Y-Phil posted Tue, 03 November 2020 at 5:50 AM
Aha... first catch. don't check "Render in a separate process" if you intend to use superfly/gpu
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
McGrandpa posted Tue, 03 November 2020 at 9:06 AM
I cannot relax on it doing POST editing at all. The renders are ALL totally out of whack with blown out lighting. That alone makes this unusable. PERIOD. I have found NOTHING that makes it stop other than not render anything at all. When the render is done, I see it for less than a second and the damned POST FX thing takes it and screws it all up.
McG.
Y-Phil posted Tue, 03 November 2020 at 9:17 AM
McGrandpa posted at 4:14PM Tue, 03 November 2020 - #4403037
I've remarked that, as it's still a pre-release, you may have to launch the PostFX thingie, change twice the settings (checkmark, sliders), and then save to "Scene settings" and to "Recent Renders" to stop this from interacting with each render.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
ghostman posted Tue, 03 November 2020 at 9:35 AM
@McGrandpa And in the render settings? Did you try to tick and untick the PostFX? As you well are aware this is still a beta with things still to fix. It's not a final release. If you find any issues then please report those to Bondware.
"Dream like you'll live forever. Live like you'll die tomorrow."
McGrandpa posted Tue, 03 November 2020 at 10:01 AM
Yeah I did Ghostman. I am aware it is a "Yah We Idiots are paying you so I can be a guinea pig!" early release. When I said it isn't quite as bad as P8 was on release day I wasn't kidding one bit. This POST FX thing isn't its only issue. Just the worst immediate one. And as I am using FireFly why is it even doing it! Its supposed to be superfly only!
McG.
McGrandpa posted Tue, 03 November 2020 at 10:21 AM
@ Y-Phil, ghostman ; working on other settings that should NOT affect that but might be. Got a single V4 Mick rendered using 'render over current bg shader' and it didn't activate that POST thing. It did both of these without hooking POST. I am leery of clicking that symbol in the render screen, that might be what sticks it on.
McG.
anupaum posted Tue, 03 November 2020 at 10:27 AM
I'm annoyed about Python scripts, but I've already vented about that in another thread. (Where did all of my P11 scripts go?) However, the Superfly render engine looks like it IS an improvement over the previous version, except for the fact that it shows the seams in the character mesh . . . I'll post about that, separately.
McGrandpa posted Tue, 03 November 2020 at 8:14 PM
I got flustered, and with no answers to this issue I did the Last Resort: Uninstall/Reinstall. And now its rendering in FF and SuperFly both, and I have not touched that scary little button in the Render screen! I dunno, maybe my cat rolled on the keyboard in some way that affected the program. I want to add, P12 has yet to crash no matter what I did to it. Solid as a rock. Which is very cool :o)
McG.
McGrandpa posted Wed, 04 November 2020 at 8:53 PM
Ok, have tried all your suggestions folks, and I appreciate all of them. Nothing helped, P12 wasn't responding where it came to THAT issue. And as I mentioned, ALL renders of any kind regardless of engine used or settings selected this one POST effect was being ran and applied to every render. And it blew out the image with brightness. So, unable to stop that, I did the good ol UNinstall/REinstall of the software. That did the trick, that worked. I can now get renders as expected from both FireFly and SuperFly, I can use POST Effects in SuperFly fine and they only apply as expected for THAT render. I now think my cat Mogwai was the cause of the problem. Well I can't think of anything else! THIS problem is now resolved.
We will be looking forward to PY scripts to be updated along the way. All in good time, and a huge thanks to all who are doing that!
McG.
Y-Phil posted Thu, 05 November 2020 at 2:25 AM
I wonder if it could not be a setting saved in Poser's default scene: I've found in my preferredState.pz3, stored in Poser's roaming profile part. I don't know how to call this part, it's in each windows user profile: "%appdata%/poser/12"
The pz3 contains this near its end: postFX { useDenoise 1 exposure 1.000000 saturation 1.000000 }
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
gabrielxdesign posted Fri, 06 November 2020 at 8:35 PM
Guys, you should contact Poser Support with these issues, the more we help, the more they can fix: https://support.posersoftware.com
Y-Phil posted Sat, 07 November 2020 at 4:04 AM
gabrielxdesign posted at 11:03AM Sat, 07 November 2020 - #4403678
Too late ? It's corrected in Poser 12.0.276
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
EClark1894 posted Sat, 07 November 2020 at 3:03 PM
gabrielxdesign posted Sat, 07 November 2020 at 8:46 PM
Y-Phil posted at 8:45PM Sat, 07 November 2020 - #4403740
Oh, ya, I just saw the last patch notes. I'm waiting, the bugs affecting me are next:
McGrandpa posted Sun, 08 November 2020 at 1:24 AM
For no reason I can find, Poser 12 has turned that "post fx" appearing thing ON by itself, no warning. I suddenly see 'render pass 1 of 3' when it should be 1 of 2. And only if SSS is being used, correct? I have found nothing in the manual yet that explains this post render lighting change for FIREFLY. Well, it is doing the same thing in SuperFly too. Settings seem to show all effects are OFF. And it is still doing this.
The finished image does look like this. Then suddenly the "system" (P12 system?) takes over, cannot interrupt it without hitting RESET (shudder).
When THIS is completed, the Outer Limits returns control of the system to me.
Went to Poser Support site, created an account (again), and opened a new ticket for P12 and this issue.
McG.
722 posted Sun, 08 November 2020 at 2:32 AM
cycle material doesn't show on objects in preview only when rendered,
McGrandpa posted Sun, 08 November 2020 at 3:04 AM
this is render in background; that IS part of the render.
McG.
ghostship2 posted Sun, 08 November 2020 at 9:11 AM Online Now!
As I pointed out in another thread, The post effects check box has a bug. You get post effects on a new file even though it is not checked. You have to toggle it on then off to turn it off.
Sharaya posted Sun, 08 November 2020 at 9:55 AM
McGrandpa posted at 9:40AM Sun, 08 November 2020 - #4402980
That's kind of why I'm here. I just installed Poser 12 yesterday, and I had a library pane that showed a La Femme folder and I managed to add my previously existing Poser content folder. It was there yesterday. Today it has a page that looks like a web browser window that didn't load a webpage right. It says "Failed to load URL http://127.0.0.1:11530/nonVirtualAssets/ContentLibrary-1.9.11/release-1.9.11/ContentLibrary/ContentLibrary.html with error ERR_ADDRESS_INVALID (-108)."
I don't know what's different between today and yesterday. When the Windows firewall thing popped up, I chose to allow network communication. That was yesterday and it was working after that, but not today. And I don't think any of the settings changed between yesterday and today. Also, I have been using DAZ Studio for some time and it's been years since I've had Poser installed, so I have about a million other issues and I don't know how many are because the software is a work in progress or how many are because I just don't know how it works.
Y-Phil posted Sun, 08 November 2020 at 10:01 AM
Normally, Windows' firewall is allowing local network connections(127.0.0.1). Are you sure that you don't have a security suite that isn't a little too "protective"? Another point to investigate: is the Events Journal containing pertinent information for this problem?
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
Richard60 posted Sun, 08 November 2020 at 10:13 AM
If you click on the YELLOW Speech button in the upper right corner it will pop up a box with all the things Poser has been doing. In there should be something about why Poser did not find the library. You can also get this if you restart Poser to fast. That is if one instance is shutting down and you try to restart it again.
mdbruffy posted Sun, 08 November 2020 at 10:32 AM
I'm going to jump in here with another issue- one I've been going over with Support for the last few days. Is anyone else aware of the fact that the ONLY way to access the content files is to allow the PROGRAM to install the content where IT wants? You can't download and install directly from the zip files like before. If you're like me and have an existing runtime set up the way you want it, Tough. You have to let the program install it's own runtime and THEN move everything to the runtime you want to to use. WASTE OF TIME AND EFFORT. Support says quote:
"The included Items are only available through the application. This is a designed limitation for the included content. You will need to use the option of install one, then move the files if you do not want to have the content in the Included Library.
You can opt to install all the items you would move to a specific Library then move those files all at one time, before proceeding to the next group of items.
I have put in a Feature Request to allow for additional options for the Library Installation from within the Poser Library, specifically for the included content."
That doesn't sound like the option I want.
Sharaya posted Sun, 08 November 2020 at 10:34 AM
Well I was all set to go on a big rant about how I've been working with computers for years and I know what I'm doing, and then I realized I had my VPN going and that was the culprit. After turning off the VPN, the product library pane is back to normal.
Y-Phil posted Sun, 08 November 2020 at 11:34 AM
Sharaya posted at 6:33PM Sun, 08 November 2020 - #4403862
Great! Nevertheless, I wonder why the VPN is interacting with the IP address 127.0.0.1? Proxy setting?
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
Y-Phil posted Sun, 08 November 2020 at 11:37 AM
mdbruffy posted at 6:34PM Sun, 08 November 2020 - #4403861
How I understand you... The last time I used the defaults folders, it was at the time of Poser 7. It resulted not only in a real nightmare, but also in a cruel labyrinth... Lol. Nevertheless, I'm used to organize my runtimes the way I want, too. But I've got the feeling that with Poser 12's content, it should be somewhat relatively organized.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
Rhia474 posted Sun, 08 November 2020 at 11:47 AM
If you mean the content that comes with the Poser 12 program, I am of no help. I already had all that content from Poser 11 since it was an upgrade for me. However, the included content always worked best when it was installed into the original program directories as far as Poser 7. Otherwise I installed content into Poser 12 with the use of File --> Install from Zip Archive' and as long as you added the libraries beforehand, it installs perfectly into the library I choose. It does not restrict me into the current Poser 12 Download. Now with all that said, I disagree with how this is delivered; they may have thought this is a help for new users (I can totally see that), but taking away the option for users accustomed to moving this whichever way they want even with a new install as opposed to an upgrade? That I can see as restrictive.
mdbruffy posted Sun, 08 November 2020 at 11:50 AM
Rhia474 posted at 11:50AM Sun, 08 November 2020 - #4403874
You're saying there's not any really NEW content? Or very little?
Rhia474 posted Sun, 08 November 2020 at 11:58 AM
I am saying as someone who has Poser 11 already, I saw no reason to mess with additional content install. I am not aware of brand new stuff that is drastically different that does not install with the base files. I mean, it actually reinstalled a new iteration of LaFemme automatically and uselessly, so... Is there a 'what is new CONTENT between Poser 11 and Poser 12' file somewhere?
mdbruffy posted Sun, 08 November 2020 at 12:33 PM
Rhia474 posted at 12:32PM Sun, 08 November 2020 - #4403880
I don't know. Last time there was any new content released for 11, it included outfits as well as full scenes- sets- ready to use.
Rhia474 posted Sun, 08 November 2020 at 1:24 PM
Yep, and I did not see anything about additional extra content for 12 when it was early released. Hence my question about whether anyone has info on whether there is difference between 11.3 content and 12 content.
Richard60 posted Sun, 08 November 2020 at 2:14 PM
If you go to PoserSoftware.com and click the downloads button you will find the link to Poser 11 files and if you go to that link you will find all the files have a date of 29 Oct 2020. So would be the latest files probably for both Poser 11 and 12.
The other way to do it is let Poser download the first set of content to the Included Runtime and copy that Runtime elsewhere and then install like you have in the past. Since each of the files you find at PoserSoftware.com is already "installed" you will have the same amount of work finding and moving each item no matter if you get the BIG Zip or let it be placed in the Included Runtime and then move that one.
Richard60 posted Sun, 08 November 2020 at 2:15 PM
There should be some updated textures for the Hivewire figures to work with SuperFly.
Y-Phil posted Sun, 08 November 2020 at 2:24 PM
Richard60 posted at 9:23PM Sun, 08 November 2020 - #4403898
I haven't downloaded these files recently but now, there's DawnSE, with her superfly skin
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
mdbruffy posted Sun, 08 November 2020 at 5:27 PM
Richard60 posted at 5:26PM Sun, 08 November 2020 - #4403897
I went and downloaded everything that wasn't marked "Legacy Content". All of that should be the older content.
McGrandpa posted Mon, 09 November 2020 at 12:53 AM
ghostship2 posted at 11:34PM Sun, 08 November 2020 - #4403849
Toggle?? How? Do that in the SuperFly settings, then go do render in FireFly? Trying that, but it's ON already by default, I guess. Good Golly! It worked! Have to close the settings page, then reopen it. Your suggestion is the ONLY thing I've tried that actually worked. After I get calmed down I will install build .276. And I only have one render done, best do some more to be sure I got it right. :)
McG.
McGrandpa posted Mon, 09 November 2020 at 1:54 AM
DING DING DING DING !!!! And GHOSTSHIP wins the imaginary Cupie Doll! Evidently, from startup to startup and New Scene just make sure to UNcheck that box in the SuperFly settings tab, then you can go to FireFly and render without the POST FX being applied. THANK YOU SO MUCH!
McG.
McGrandpa posted Mon, 09 November 2020 at 3:29 AM
mdbruffy posted at 2:25AM Mon, 09 November 2020 - #4403861
Welcome to the club! That is reprehensible of them, to do that without Vaseline or even a crooked sadistic grin. It's bad enough when they crammed a wad of stuff into each zip, then loaded us up with a dozen and more zips. But that gave us a few more options at least. This gives us exactly TWO: Their way or SCREW it.
McG.
McGrandpa posted Mon, 09 November 2020 at 3:31 AM
Ghostship's Way still works! Oops, I just updated to build .276, better see if it works right or...or whatever!
McG.
mdbruffy posted Mon, 09 November 2020 at 3:58 AM
Support says quote:
Agreed. Who knows what those "additional options" will be. Somethings shouldn't be changed.
dlfurman posted Mon, 09 November 2020 at 7:39 AM
"Those who ride the bleeding edge of technology are often sacrificed on it!' Thank you for your sacrifices EARLY ADOPTERS... (Oh, Wait. I'm one too!)
space
McGrandpa posted Mon, 09 November 2020 at 10:38 AM
A gigabyte of content, all in the wrong place(s). BUT...its "free" yeah?
McG.
McGrandpa posted Mon, 09 November 2020 at 10:44 AM
I have a question, can we get a tab in the Materials Room for the old "Simple View"? It has things in it that make it a lot easier than digging a hole through our monitors looking for the items. The NEW tab is sorta cool, but its usefulness is debatable as you got no idea what the texture already IS while in it. There are no longer the images to show us what is there we want to do something about. We need to SEE these things!
McG.
McGrandpa posted Mon, 09 November 2020 at 10:52 AM
Another one pops up, while in use. In The Library, we need to be able to expand/shrink the width of the Runtimes roll down List box. Also, can you add drag n drop to the Runtimes NAMES in that list?
McG.
ChromeStar posted Mon, 09 November 2020 at 2:39 PM
These issues would probably have more visibility and provide more opportunity for others to test them out and comment if you put them in separate threads.
mdbruffy posted Mon, 28 December 2020 at 9:29 AM
New issue- or maybe an old one. I went to the Poser site and downloaded the following zips:
La Femme_BonusContent_01
La Femme_BonusContent_02
PoserPremiumContent_3DScenery_01,02,03
All of these were EMPTY zips. There was NOTHING to unzip. Has anyone else encountered this?
mdbruffy posted Thu, 07 January 2021 at 3:37 PM
Hello? anyone here?
Rhia474 posted Thu, 07 January 2021 at 3:48 PM
Apparently not.. site really slowed down after the holidays. Have you tried adding a help ticket?
Miss B posted Thu, 07 January 2021 at 4:02 PM
Y-Phil posted at 4:00PM Thu, 07 January 2021 - #4403869
I use that as part of the URL link for my External Library, which I view in my browser. I don't have a VPN, so can't say why it's interacting with that IP address.
_______________
mdbruffy posted Thu, 07 January 2021 at 4:10 PM
Rhia474 posted at 4:10PM Thu, 07 January 2021 - #4409663
I was hoping there was already a solution or fix. I guess I'll have to.
Miss B posted Thu, 07 January 2021 at 4:12 PM
mdbruffy posted at 4:10PM Thu, 07 January 2021 - #4408801
Have you tried downloading these again, because I was just able to re-download LaFemmme_BonusContent_01 zip without an issue, and it contained the whole 1.1GB it's supposed to contain.
_______________
mdbruffy posted Thu, 07 January 2021 at 4:17 PM
Maybe they fixed the problem then. I'll give it another try.
