Forum: Poser 12
Subject: CPU rendering
RedPhantom opened this issue on Nov 04, 2020 ยท 48 posts
RedPhantom posted Wed, 04 November 2020 at 6:50 AM Site Admin
I know a lot of focus is on the GPU rendering because it's so much faster. Who wouldn't want a render done in 5 minutes rather than 5 hours? But has anyone tried the problematic shaders in a CPU rendering. If I recall, the GPU and CPU rendering always was different.
ghostman posted Wed, 04 November 2020 at 7:44 AM
from what i've seen so far there's no diff. but then again i'm colourblind. ;)
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
Rhia474 posted Wed, 04 November 2020 at 7:54 AM
Same issue with shaders regardless of what you render with, CPU or GPU. Updated Cycles break Superfly rendering of previously used skins and a lot of material shaders.
ghostship2 posted Wed, 04 November 2020 at 8:59 AM
@RedPhantom The issue in the past with CPU renders looking different than GPU render was down to the clamp settings. In CPU it turned this off and (no clamping) so CPU would calculate for ALL the lighting while it turns clamping on for GPU and you can experiment with how much clamping there is. The issue was that it was never really explained to the users this would have a profound impact on SOME renders. It matters how many lights you have and how small and intense they are. It took me more than a year to figure out what exactly was going on with the renders just because it wasn't all renders. Very puzzling.
Rhia474 posted Wed, 04 November 2020 at 9:19 AM
Wow. So, this should have been in the manual or at least in some tutorials and never got there?
hborre posted Wed, 04 November 2020 at 9:27 AM
It looks more like no one either never notices or didn't bother to pursue further testing. I wonder if anyone opened a ticket on it.
ghostship2 posted Wed, 04 November 2020 at 10:46 AM
hborre posted at 9:38AM Wed, 04 November 2020 - #4403213
It's not a bug, It's just the way Superfly is. It's just that there was never any official explanation as to why renders would look different. Turning clamping off makes fireflies in renders with super high dynamic range lighting. The HDR images that are dark with one or more super bright points of light in them are the ones that show this the best. The fireflies are not render errors, they are HIGHLIGHTS that take a huge amount of time to calculate. If you let the image render for 100 samples or more you will see the patterns emerge and turn into bright highlights from the sun or small, bright lamps in the hdri. Using the background to light a scene works way better but the background image is all twisted around.
hborre posted Wed, 04 November 2020 at 12:07 PM
Ah, that explains a bit of what I've been seeing in conjunction with some information I read in the manual. Believe me, I read those paragraphs multiple times just to make sure I understood the concept. Now, you mentioned super high dynamic range lighting and its effect on increased fireflies with unclamped rendering, am I correct to assume that if I use a lower range HDRI under the same conditions I would eliminate most, if not all, fireflies sacrificing some highlighting? This is intriguing and deserves a closer look. Thanks.
ghostship2 posted Wed, 04 November 2020 at 12:42 PM
@hborre Yes, the lower the dynamic range the cleaner the render. The cleanest will be if you use a jpg instead of an HDRI. This is if you are using a dome for lighting. If you use the background as your HDRI then it renders cleaner AND you get the highlights from lamps and the sun in the image. I still haven't figured how to sort out the way the background image is all flipped around when using that. using the background for lighting is also SUPER fast. Have a look at the lighting results. That huge highlight on the figure is from the background. There are no lights used in this render.
RedPhantom posted Wed, 04 November 2020 at 1:17 PM Site Admin
Thanks all for indulging me. This is interesting
hborre posted Wed, 04 November 2020 at 1:18 PM
This has been very insightful. I definitely want to play around with this further. I do have some sIBL and HDRI editing programs on my system that can assist in manipulating images I have downloaded. Thank you very much for the informative clarifications.
bantha posted Wed, 04 November 2020 at 3:43 PM
The twisted backgroundimage can be fixed with a mapping node. I posted the setup in my posting about the shadow catcher.
Rotation value in the mapping node: 4.900000, 3.150000, 0.000000
A ship in port is safe; but that is not what ships are built for.
-"Amazing Grace" Hopper
Avatar image of me done by Chidori
bantha posted Wed, 04 November 2020 at 3:45 PM
Works:
HDRI-Image on the background shader.
Y-Phil posted Wed, 04 November 2020 at 4:13 PM
bantha posted at 11:12PM Wed, 04 November 2020 - #4403299
Thank you so much ?
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐Ÿ‘ฟ Nas 10TB
ghostship2 posted Wed, 04 November 2020 at 4:22 PM
for some reason those settings don't do anything to make the background image upright for me.
hborre posted Wed, 04 November 2020 at 4:24 PM
@ghostship2: I have been playing with your node arrangement for background projection of HDRI maps and I would like to make a recommendation. Use the Normal connection on the TextureCoordinate instead of Generated, and on the Mapping node change the Vector Type to Texture instead of Point. I believe this will invert the projection. Use the upper Location, Rotation, Scale values to control the translation of the background.
ghostship2 posted Wed, 04 November 2020 at 4:25 PM
I think I figured it out. It's the first set of rotation numbers not the second
ghostship2 posted Wed, 04 November 2020 at 4:27 PM
@hborre cool! I'll take a look at that.
hborre posted Wed, 04 November 2020 at 4:35 PM
Yes, the first set works.
hborre posted Wed, 04 November 2020 at 4:52 PM
Here we go. Quick render using LF and an 8K HDRI. The higher the resolution the better the background sharpness. To be honest, try to cap it off at 4K. Below are the changes I made to the nodes, I think it works better. Using a 360-degree panorama, I set the x rotation to 90.
ghostship2 posted Wed, 04 November 2020 at 4:55 PM
yes, getting good results with this. Remember to set clamping to 0 and turn off any extra lights you have. Let the background light the scene. The highlights in her eyes really pop with this lighting. P12 Background light test.jpg
ghostship2 posted Wed, 04 November 2020 at 4:59 PM
@hborre Don't bother with huge HDRI's. I always use DOF blur to separate the figure from the background and then only need the smaller (2k) size images. More than that and you are using precious GPU ram for the background.
Rhia474 posted Wed, 04 November 2020 at 5:01 PM
Okay, can I ask some really stupid questions? What are you putting the HDRI on? And what are those unconnected nodes in your setup?
ghostship2 posted Wed, 04 November 2020 at 5:07 PM
@Rhia if the node is unconnected then don't worry about that. I have some voodoo about nodes for the background lighting setup because lighting a scene this way in P11 was serious Poser crash time. Looks like it is pretty stable now!!!!! This is what we are talking about: what im talking about.jpg
hborre posted Wed, 04 November 2020 at 5:09 PM
Go into the Material Room and pull down the contextual menu on Object on the right. In the menu, you will see Background. The disconnected nodes are for either image projection or colorization.
ghostship2 posted Wed, 04 November 2020 at 5:44 PM
another example of studio lighting with the background object. No lights used for this render. P12 background 2.jpg
hborre posted Wed, 04 November 2020 at 5:53 PM
Beautiful render.
Rhia474 posted Wed, 04 November 2020 at 6:24 PM
Neat, now I just have to figure skin shaders that don't look like ass. Thanks guys!
Rhia474 posted Wed, 04 November 2020 at 6:45 PM
So everything works beautifully, but the background image does not show on the render. It is an HDRI. What am I doing wrong?
hborre posted Wed, 04 November 2020 at 6:48 PM
Good luck. Right now, I'm experimenting with an HSV and color node to tint the background and change the HDRI light output. Getting some nice surreal effects.
hborre posted Wed, 04 November 2020 at 6:49 PM
Did you hide the construct?
Rhia474 posted Wed, 04 November 2020 at 6:53 PM
Yeah, I start with a plain scene without construct.
Rhia474 posted Wed, 04 November 2020 at 6:58 PM
The grey background is with GPU rendering. With CPU, what I am getting is the 'floor of the image, if you will. cputestlyn.jpg
I'm sure it's a simple answer, so sorry for all the questions. This program version forces me to stumble around like a complete noob for Poser after such a long time using it. Thanks for answering me!
hborre posted Wed, 04 November 2020 at 7:04 PM
The rotation first number should be set to approximately 90-degrees to appear normal. Click on the first rotation value at the top, you will notice 3 numbers separated by commas. In order, the numbers correspond to X, Y, Z-degrees global axis. Those numbers should look like this: 90.00, 0.00,0.00. Adjust as needed to match the HDRI.
Rhia474 posted Wed, 04 November 2020 at 7:10 PM
Ahh. Thank you.
Y-Phil posted Thu, 05 November 2020 at 10:03 AM
Lol.... I don't get anything working with your settings... I have to enter -90ยฐ for X, but in radians:![Sasha-Jinky7.jpg]
I've tried Point -> generated and texture -> normal: no success. Anyway, it looks like I've found something working, yay ?Sasha-Jinky7.jpg
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
Y-Phil posted Fri, 06 November 2020 at 4:58 AM
Looks like the background node is loosing its rotation and scale parameters upon reloading a Poser project file...
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
Rhia474 posted Fri, 06 November 2020 at 7:30 AM
Ugh. I'll test that after work today, but if so, that is a bug to be filed.
ghostship2 posted Fri, 06 November 2020 at 11:18 AM
Y-Phil posted at 10:15AM Fri, 06 November 2020 - #4403582
Same issue here. Also after changing the rotation values back to something usable Poser still not registering a change to the file so "save" is still greyed out. Also last night I edited a file and then clicked the "X" in the upper right corner to close the program and Poser just quit without any warning about saving my work.
ghostship2 posted Fri, 06 November 2020 at 11:21 AM
I just tried to force save the file after changing the rotation values of the Mapping node. "Save As..." did not save the changes either.
ghostship2 posted Fri, 06 November 2020 at 11:26 AM
Saving the background shader as a preset doesnt work either. The rotation setting reset to 0,0,0
Y-Phil posted Fri, 06 November 2020 at 3:18 PM
ghostship2 posted at 9:58PM Fri, 06 November 2020 - #4403620
You've experimented that same effects as me. I suppose that the devs consider the atmosphere, the background and probably the universe objects as more or less read-only: editable as long as nothing important is changed, except when a scene is imported for example....
From what I've understood, these parameters are effectively stored in the PZ3 file (near the end) but it looks like they are not interpreted
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
ghostship2 posted Fri, 06 November 2020 at 3:26 PM
Y-Phil posted at 2:24PM Fri, 06 November 2020 - #4403634
It's a problem with the mapping node itself. I have a previous version of this background shader that is saved to presets that works fine in P11.
Rhia474 posted Fri, 06 November 2020 at 3:30 PM
Everything worked in P11. Le sad sigh.
Y-Phil posted Fri, 06 November 2020 at 5:30 PM
Good news: the Background node parameters seem to be restored upon loading a scene, with Poser 12.0.276
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
Rhia474 posted Fri, 06 November 2020 at 5:57 PM
I saw the release notes and was hopeful I interpreted that correctly. Yay!
ghostship2 posted Fri, 06 November 2020 at 8:21 PM
OK. Now that it's working can someone smarter than I explain the 3 coordinates? what value rotates the image by 90 degrees or 180 degrees? Is there a way to have the background show up in preview so I don't have to guess where the image is rotated to?
Y-Phil posted Sat, 07 November 2020 at 3:22 AM
ghostship2 posted at 10:20AM Sat, 07 November 2020 - #4403675
From what I remember of trigonometry: 90ยฐ = 1.57 (rad) = 100 (grad) = a quarter of a circle
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
