Forum: Poser 12
Subject: AnisotropicBsdf BROKEN - Anisotropic Reflection NOT SUPPORTED in Poser 12
noobalien opened this issue on Dec 06, 2020 · 18 posts
noobalien posted Sun, 06 December 2020 at 8:59 AM
The AnisotropicBsdf node is not working correctly in Poser 12. In addition, the Cycles Input Tangent node is missing the 'UV Map' Direction parameter.
Furthermore, the Legacy Firefly Anisotropic node has stopped working under Superfly in Poser 12. Therefore, it is not possible to render any correct anisotropic reflections in Poser 12.
It is very disappointing to find that nodes and shaders that worked in version 11 are not working anymore. When I downloaded the trial version I hoped it would be an improvement over the previous version but instead I found there were broken nodes, and the entire program is much slower.
hborre posted Sun, 06 December 2020 at 10:52 AM
The problem has been reported to the development team and hopefully, it may be corrected on the next update.
structure posted Sun, 06 December 2020 at 10:57 AM Forum Coordinator
jamsan posted at 10:56AM Sun, 06 December 2020 - #4406562
Jako bardziej codzienna praktyczna definicja, odbicia anizotropowe są jak zwykłe odbicia, z wyjątkiem rozciągniętych lub rozmytych w oparciu o orientację małych rowków (nierówności, włókien lub zadrapań), które istnieją na odblaskowej powierzchni. izotropowy: właściwości materiału są identyczne we wszystkich kierunkach. anizotropowy: ici właściwości materiału zależą od kierunku; na przykład drewno. Na kawałku drewna możesz zobaczyć linie idące w jednym kierunku; kierunek ten nazywany jest female kigurumi „z ziarnem”.
Translation ( as close as possible )
As a more everyday practical definition, anisotropic reflections are like ordinary reflections, except for stretched or fuzzy ones based on the orientation of small grooves (unevenness, fibers, or scratches) that exist on the reflective surface. isotropic: the material properties are identical in all directions. anisotropic: the material properties depend on the direction; for example, wood. On a piece of wood, you can see lines going in one direction; this direction is called female Kigurumi "with the grain".
Locked Out
Afrodite-Ohki posted Sun, 06 December 2020 at 11:08 AM
structure posted at 11:06AM Sun, 06 December 2020 - #4406569
Yup and that's a spam bot. Notice they took a word from the thread and returned a random piece of vague information about that word, with a sneaky link into the text. Same person did that in some five other threads that I noticed.
Feel free to call me Ohki!
hborre posted Sun, 06 December 2020 at 11:21 AM
Definitely an annoyance. I'm completely setting this individual on the ignore list.
ghostship2 posted Sun, 06 December 2020 at 11:48 AM Online Now!
is that Polish?
hborre posted Sun, 06 December 2020 at 11:50 AM
It's been spamming in different languages.
Rhia474 posted Sun, 06 December 2020 at 11:51 AM
Yes, and they are spamming on multiple languages--there is French on another thread and English on another. A clever spambot.
structure posted Sun, 06 December 2020 at 12:13 PM Forum Coordinator
being dealt with
Locked Out
Afrodite-Ohki posted Sun, 06 December 2020 at 1:42 PM
structure posted at 1:42PM Sun, 06 December 2020 - #4406583
being dealt with
Thank you!
Rhia474 posted Sun, 06 December 2020 at 2:57 PM
Wonderful, thank you.
noobalien posted Thu, 10 December 2020 at 3:03 PM
"It may be fixed in a future update" "being dealt with"
That's okay. I may buy your software in the future, then. Meanwhile I'll stick with Poser 11.
Rhia474 posted Thu, 10 December 2020 at 5:57 PM
Being dealt with is referring to the spambot spewing all over the forum and it being traced and eliminated, not what you said. And just how do you expect the devs to deal with a bug? In a future update. As the poster who said ' hopefully in the next update' was not a dev, they could hardly have given you the exact date of the fix. it was reported, it was put on the list.
noobalien posted Fri, 11 December 2020 at 1:10 AM
Rhia474 posted at 12:47AM Fri, 11 December 2020 - #4406989
Okay, yet the nodes are still broken and terefore, shaders that worked in v11 stil don't work in v12 If the nodes are fixed, buying a license may be worth consideration then. If.
Demanding users to pay hundreds of dollars for a license to run a bug that may never be fixed? That is quite a bold business decision.
hborre posted Fri, 11 December 2020 at 7:57 AM
In the past, Bagginsbill would find odd behaving nodes years after the implementation of the software, but we're talking about an individual with extensive training in computers and programming.
ghostship2 posted Fri, 11 December 2020 at 8:32 AM Online Now!
these bugs are known and are being tracked and worked on. The devs really are working on fixing all the issues with12.
hborre posted Fri, 11 December 2020 at 9:07 AM
Bless their pointy little heads.
noobalien posted Fri, 11 December 2020 at 3:10 PM
hborre posted at 2:59PM Fri, 11 December 2020 - #4407089
Now that you mention Bagginsbill, is he still around? I wonder if he has quit Poser too, I wouldn't blame him giving up with this mess. All the shaders I use are based on BB's model for PBR.
