3dcheapskate opened this issue on Dec 08, 2020 ยท 3 posts
3dcheapskate posted Tue, 08 December 2020 at 6:17 AM
I posted this question over on the DAZ Poser forum a couple of weeks ago as Anybody recall the Poser fix to get Freak 4 working without that dent in his biceps ? because the Renderosity forums weren't working.
Kerya pointed me at Lyrra Madrill's Michael 4 arm fix freebie on ShareCG which does indeed fix the problem.
But what I'm actually after is the explanation, which I'm fairly sure that I read in a thread here on the Renderosity* forums.
I've used both Renderosity's own forum search and Google to try and find the thread, but with no luck.
Does anybody have the link ?
*it could have been the RDNA forums
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
3dcheapskate posted Fri, 11 December 2020 at 7:21 PM
Answered over on the equivalent DAZ Poser forum thread there.
raven posted Mon, 14 December 2020 at 10:15 AM
I know you have found your answer but in case anyone else is interested, I think this may have been what you were after here. Not an explanation of why it happened, but shows the fix needed.
https://www.renderosity.com/rr/mod/forumpro/?thread_id=2855184
