KaoticLord opened this issue on Dec 10, 2020 ยท 9 posts
KaoticLord posted Thu, 10 December 2020 at 5:54 PM
So I've been Googling like crazy but can't find a damn thing. Where do I download the Poser 11 support files from?!
structure posted Thu, 10 December 2020 at 7:22 PM Forum Coordinator
In poser 11 / 12 you will find the extra content files in the purchases tab on the library panel.
the support files are installed with the main program.
Locked Out
KaoticLord posted Fri, 11 December 2020 at 2:10 AM
I don't seem to have them. "Poser Reference Manual.pdf" just tells me to go download and install them. I have Poser 11.0.8.34338, if that means anything.
RedPhantom posted Fri, 11 December 2020 at 6:13 AM Site Admin
go to https://www.posersoftware.com/downloads/11 enter your serial number when asked. then you'll get a list of download files, including one called posersupport.exe.
hborre posted Fri, 11 December 2020 at 7:59 AM
You might as well update your software while you're at it. The current and final version is 11.3.818.
structure posted Fri, 11 December 2020 at 9:42 AM Forum Coordinator
KaoticLord posted at 9:39AM Fri, 11 December 2020 - #4407062
11.0 is the last smith micro version of the software and will no longer work correctly ( if at all ) . Since ownership has changed, you should update your software as suggested by hborre.
Locked Out
Seliah posted Fri, 11 December 2020 at 4:00 PM
Question : My version of Poser is 11.2. To update to the current/Bondware version, should I just run the installer exe for 11.3? Do I need to uninstall 11.2 first?
Thanks in advance.
structure posted Fri, 11 December 2020 at 4:20 PM Forum Coordinator
Seliah posted at 4:20PM Fri, 11 December 2020 - #4407149
Thanks in advance.
You can do either, installing over 11.2 would give the added option of retaining your current settings.
Locked Out
Seliah posted Fri, 11 December 2020 at 6:10 PM
OK. Thanks very much!
