ssmith opened this issue on Jan 12, 2021 ยท 16 posts
ssmith posted Tue, 12 January 2021 at 10:02 AM
My poser 10 library no longer works. It's a flash problem. Any fixes? See attached.
donnena posted Tue, 12 January 2021 at 11:29 AM
A quick and dirty fix is to use File Explorer instead, and just drag the assets onto the stage.
Andy!
hborre posted Tue, 12 January 2021 at 7:08 PM
I agree with the solution response by donnena. Flash is officially not supported anymore.
ussadventure posted Wed, 13 January 2021 at 10:11 AM
I use Poser 10...any updates to counter flashplayer's shutdown??? and is this affecting later versions of poser as well? Not going to waste money in an upgrade if it's affecting newer versions.
hborre posted Wed, 13 January 2021 at 10:26 AM
P11 and P12 do not use Flash anymore. Here is a link to the best solution to continue using P10: https://www.renderosity.com/rr/mod/forumpro/?thread_id=2956792&page_number=2#msg4410118
Badgermedicine posted Wed, 13 January 2021 at 7:37 PM
Hey there, I had the same thing happen to me, Adobe strikes again!! this is not the first time they have done this sort of thing, Still, there is a fix, that will save your Poser 10 and Poser 2014 Pro, program. I have done this and Saved my Poser Pro 2014, and effectively snatch a Victory from the Jaws of a Adobe FLASH defeat. this worked on a PC so it should work on MAC
I found Pumeco's "NO MORE FLASH!!!!!!" thread in the Renderosity Poser forums, including this post from bagginsbill. Here's the text of that post, although it's recommended to read the whole thread as that gives more context:
I think I found the setting - it was introduced in Poser 10 and then rescinded - probably because it doesn't work right somehow.
Exit Poser if it's running.
Find your poser.ini - the path may differ for you - mine is in
c:/Users//AppData/Roaming/Poser Pro/10
In your poser.ini look for
LIBRARY_EMBEDDED_TYPE 0
and change the 0 to a 1.
In Poser 10, this is (I think) all you would do. For Pro 2014, you'd need to choose the embedded library as well with this line:
LIBRARY_IS_AIR 0
That was bagginsbill's work-around to stop Poser using the Flash library, and was confirmed by pumeco for Poser 10). Here's a screenshot (copied from that post/thread) showing the non-flash Poser library.
Badgermedicine posted Wed, 13 January 2021 at 7:53 PM
Just so you know: essentially what your doing by making the above changes, is telling Poser to not use Adobe Flash. this will change the way the Libraries work to a degree, they we most likely open in a second window, but you will have access to them again, make sure you adjust the Library setting to "all". If you need further help message me.
milestugo posted Thu, 14 January 2021 at 8:21 PM
Not sure why my library is offline and the flash symbol replaced it. I know Flash was removed but not sure why the library was affected. I am currently using the Poser 2014 pro program. I do have the Poser 11 however. If I load this onto my computer will its library work and if so will i be able to use my runtime library with it? Is there a work around for poser 2014 pro to get the library working again? I tried to find the poser.ini but it came up empty. I even searched for the other listed files and nothing came up. Any help will be appreciated. Thank you :)
hborre posted Thu, 14 January 2021 at 8:31 PM
You will need to unhide your hidden files and folders to find the specified locations. As for your runtimes, you can link them to Poser 11 and they will work just fine.
Badgermedicine posted Thu, 14 January 2021 at 11:13 PM
hborre is correct, if your using a PC and have Windows, be sure to log in as administrator, doing so will allow you full access to change the file properties and unhide the file. the file your looking for can then be opened with notepad. it's the configuration settings file.
milestugo posted Sat, 16 January 2021 at 6:46 AM
How can I import figures from Poser 2014 pro (Katie and Ben figures are not in the poser 11 package I assumed the base figures were included as well as the P4 characters as they have been in past versions. I tried the work around and I do gain access to the library in poser 2014 pro. I just cant anchor it on the screen like before. I can live with that. Allows for a bigger work area anyway. Eventually I will want to move to 11 and then 12 when its finally out and the bugs are cleaned up. i noticed that the old figures from P4 on are not included in poser 11. Is there a way to bring them into poser 11? If not, with the main poser 10 figures be able to be exported such as G2 versions (James And Jessi, Ben and Kate, Sydney and so on?) Many of my animations use these and their morphs and I would hate to think I just lost all that investment (props and gear) and would have to start from scratch. besides there is not many choices with Poser characters and or their attire. (Certainly not as much as DAZ figures.) Anyway Thanks for all your help ! :)
RedPhantom posted Sat, 16 January 2021 at 7:55 AM Site Admin
in your poser 11 library, click on the set up books with the plus (see the circled part of the image) to add your 2014 runtime. Then just point to where your old runtime was.
If you want to anchor it to the screen, click on the little arrow near the other red tick in my image. That gives you the choice to dock (anchor) or float the library.
If you are missing content, check here Poser content downloads You'll need to enter your serial number. Ben and Kate look to be in the 04_LegacyContent_Poser-Figures.zip file.
milestugo posted Sat, 16 January 2021 at 10:17 PM
Thank you! That is awesome.
Badgermedicine posted Sun, 24 January 2021 at 1:04 PM
HI all, Some users have contacted me with additional questions, So I will post the answer here as well.
Here are some notes to help you out. first I take it your on a PC and not a MAC. 2. you are logged in to your computer as an administrator.
c:/Users//AppData/Roaming/Poser Pro/10 (note; you should see several files here, Poser.ini being the file you want) (Not seeing it? adjust the file properties, so you can.) (Won't let you edit? then login as an administrator) (Bigger problems? find a genie, good luck getting her back in the bottle)
Open the file in NotePad. you will see several lines of code/instructions for Poser to following upon being started. there are just two lines of that code you want to change. see the example below
1st line: LIBRARY_EMBEDDED_TYPE 0 (and change the 0 to a 1) 2nd line: LIBRARY_IS_AIR 0 (and change the 0 to a 1) now save your change and exit the file.
This change should effect all Poser Pro applications on your computer regardless of where they are located. if for some reason it does not, write me back. I use a PC, not a MAC (sorry MAC users)
Find your poser.ini (this is a file, that once clicked on will open in NotePad) - the path may differ for you - mine is in c:/Users//AppData/Roaming/Poser Pro/10 In your poser.ini look for LIBRARY_EMBEDDED_TYPE 0 (and change the 0 to a 1.) In Poser 10, this is (I think) all you would do. For Pro 2014, you'd need to choose the embedded library as well with this line: LIBRARY_IS_AIR 0 (and change the 0 to a 1.)
mr_red posted Tue, 26 January 2021 at 11:38 AM
thanks to Badgermedicine for the heads up on the fix, got the shock of my life today when i came to use poser (i only use it these days for making ref pics) I really thought my poser days were over and almost uninstalled but thanks to the help here it was saved from the big boot.
wolfesbain posted Sat, 06 February 2021 at 1:05 AM
Is there a flashplayer emulator out there that can take the place of Flash and allow the library to re-appear poser 9. These 3rd party apps are absolute crap, and I haven't been able to correctly import anything into Poser 9. I can import stuff, but it always gets messed up. I can't afford an upgrade right now and I am REALLY wanting to get back to my art creation. PLEASE GOD, SOMEONE HAVE A SOLUTION! I Don't want to go over to Daz!
