zander opened this issue on Jan 13, 2021 ยท 14 posts
zander posted Wed, 13 January 2021 at 12:00 PM
Is there an EASY manner to get rid of content that I'll never use? Other than searching for all aspects of each content and deleting each aspect manually? There's a lot of "free" content that I find that I'd never use.
hborre posted Wed, 13 January 2021 at 12:25 PM
Easy? No, I'm afraid. However, if you have P3DO Explorer installed, you can branch down the hierarchy to associated files. There is a free version available so you don't need to layout extra cash just to clean up your runtime.
Afrodite-Ohki posted Wed, 13 January 2021 at 2:14 PM
What I did was make a new runtime and install into it everything that I DO use. I found that much easier.
Feel free to call me Ohki!
structure posted Thu, 14 January 2021 at 8:26 PM Forum Coordinator
Use a script to run through your file to search for file references,
from there look at the folder names and determine if they contain anything you need,
if not, delete them
from __future__ import print_function
import os
import os.path
class _dialogs:
def get_folder( self, start = "" ):
style = ( wx.DD_DEFAULT_STYLE | wx.DD_NEW_DIR_BUTTON )
dialog = wx.DirDialog( None, 'Select a Folder ', start , style )
return dialog.GetPath() if dialog.ShowModal() == wx.ID_OK else False
ignore_exts = ( ".png", ".xmp", ".obj" )
searchfolder = _dialogs().get_folder()
list_of_files = os.listdir( searchfolder )
for file in list_of_files:
file = os.path.join( searchfolder, file )
print( file )
if not file.endswith( ignore_exts ):
try:
with open( file, "r" ) as lines:
for line in lines:
if "runtime" in line.lower():
print( line )
except:
continue
**This does not take into account compressed files
Locked Out
structure posted Thu, 14 January 2021 at 9:53 PM Forum Coordinator
This script works with both normal and gzipped files
import gzip
import os
import os.path
import sys
class _dialogs:
def read_lines( lines, isgzipped, references = [] ):
if isgzipped:
lines = lines.split("\n")
for line in lines:
if "Runtime" in line.title():
if not line.lstrip() in references:
references.append( line.lstrip() )
return references
def has_extension( object_type ):
try:
ext = os.path.splitext( object_type )[1]
except:
ext = None
if ext:
return True
else:
return False
def is_gz_file(filepath):
with open(filepath, 'rb') as check_gz_status:
return check_gz_status.read(2) == b'\x1f\x8b'
def print_references( references ):
if references:
for ref in references:
print( ref.rstrip() )
def legal_file_types():
return ('.pz3','.cr2','.pz2','.pp2','.hr2','.fc2','.hd2','.lt2','.cm2','.mt5','.mc6',
'.pzz','.crz','.p2z','.ppz','.hrz','.fcz','.hdz','.ltz','.cmz','.mz5','.mcz')
use_exts = legal_file_types()
underline = '-'*30
references = []
sysop = False
if searchfolder:
if file.endswith( use_exts ):
if has_extension( file ):
if sys.version_info.major == 3:
sysop = True
print( f"\n\nExamining {file}\n{underline}\n" )
elif sys.version_info.major == 2:
sysop = True
print( "\n\nExamining {}\n{}\n".format( file, underline ) )
else:
sysop = False
print( "Python 2 or 3 is required to run this file.")
if sysop:
if not is_gz_file( file ):
try:
references = read_lines( lines, False, references )
except:
continue
else:
with gzip.open( file ,'rb' ) as lines:
lines = lines.read()
lines = lines.decode("utf8")
references = read_lines( lines, True )
references = []
this gives an output resembling this:
Examining x:\\Poser\\Runtime\\Libraries\\Character\\Creepy Kid Too\\Creepy Kid 2 WM 9+.cr2
figureResFile :Runtime:Geometries:Creepy Kid Too:Creepy Kid Too.obj
textureMap ":Runtime:Textures:Creepy Kid Too:TeethGums.jpg"
file ":Runtime:Textures:Creepy Kid Too:TeethGums.jpg"
textureMap ":Runtime:Textures:Creepy Kid Too:EyesTex.jpg"
file ":Runtime:Textures:Creepy Kid Too:EyesTex.jpg"
reflectionMap ":Runtime:Textures:Creepy Kid Too:EyesTex.jpg"
bumpMap ":Runtime:Textures:Creepy Kid Too:TeethGums.jpg"
textureMap ":Runtime:Textures:Creepy Kid Too:Body.jpg"
file ":Runtime:Textures:Creepy Kid Too:Body.jpg"
file ":Runtime:Textures:Creepy Kid Too:displace.jpg"
Locked Out
NikKelly posted Mon, 18 January 2021 at 2:09 PM
Ah... I made that mistake with P_4, greeted 'external runtimes' with much glee. So, now, I've a swathe of mildly organised model folders, each with one model or set's runtime, spread across three drives. I only 'mount' those I need to Poser's library.
unrealblue posted Fri, 05 March 2021 at 5:27 AM
Afrodite-Ohki posted at 5:19AM Fri, 05 March 2021 - #4410209
Truly!
randym77 posted Fri, 05 March 2021 at 7:54 AM
NikKelly posted at 7:51AM Fri, 05 March 2021 - #4410652
That's what I do. Each figure gets its own runtime, and I have other runtimes for different themes. (Fantasy, sci-fi, contemporary, horror, animals, nature, etc.) Though so far, it all fits on one (pretty big) drive.
HartyBart posted Sun, 07 March 2021 at 4:11 AM
If disk-size, rather than Library-clutter, is the problem then one way is to run the free WinDirStat on your runtimes. It will give you a visual display in which you can easily see the largest files. You can then decide what to do with each big item. Is it connected with content you're ever likely to use? If not, then you delete it or archive it. You can get yourself several Gb of space this way, from a large 20-year runtime. Especially useful for more recent DAZ Studio content, where recent hair meshes and textures can be stupidly large.
McGrandpa posted Sun, 14 March 2021 at 8:18 PM
Well. Kinda eliminates us using the free content that comes with Poser. I am super picky about what goes into my Runtimes. Therefore, unless Rendo breaks that Free! content down into individual items, I don't even download it any more. Of course, THEY do install a bit of mashup crap when you install Poser. :(
My 66th Birthday PC Build (July 1, 2020) : named BadMoonRYZEN!, W10Pro x64, Octal Core RYZEN7 X3700 4.05 GHz, 64GB DDR4 RAM, GeForce RTX 3060 - 12GB GDDR6, PP2014, PP 11, P12, PS-CS4 Extended & Vue 2024.
McG.
ChromeStar posted Mon, 15 March 2021 at 10:36 AM
You can download it selectively from https://www.posersoftware.com/downloads/content (with your serial number). Then install in a new runtime. Not using it? Delete the runtime. Easy.
I do find it annoying that every version of Poser wants to install all the old content in a new runtime. I already have multiple versions of that, please stop. Not sure whether Poser 12 has an option to just install all the new stuff.
Navim posted Mon, 15 March 2021 at 12:06 PM
Just upgraded to vers 12 after much difficulty and find that most of the content including recently purchased items will not load. Under the Purchases tab the download bar goes to 100% and then reverts to the Reinstall bar. This happens repeatedly. Help and suggestions greatly appreciated. I have too much money invested to quit now.
RedPhantom posted Mon, 15 March 2021 at 1:33 PM Site Admin
When content is installed, it switches to reinstall to show it's been installed but gives you a chance to reinstall it if you need to.
In the top line, the garden patio installed, but Poser didn't know what to do with the template. If you click on the manually install, it will open explorer to allow you to open the zip file to extract the template. the second line installed without a problem.
Navim posted Mon, 15 March 2021 at 2:12 PM
Thank you for a clearly presented answer!
