jadeite123 opened this issue on Jan 16, 2021 ยท 5 posts
jadeite123 posted Sat, 16 January 2021 at 5:36 AM
When I run a script with [File]-[Run Python Script] on the Windows version of 12.0.340, I get an error.
It seems that the error occurs depending on the pathname.
D:\usr\poser\scripts\test.py
import sys
print(sys.version)
Results
File "", line 1
SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in position 2-3: truncated uXXXX escape
3.7.9 (tags/v3.7.9:13c94747c7, Aug 17 2020, 18:58:18) [MSC v.1900 64 bit (AMD64)]
Is "\usr" in the pathname interpreted as an escape in the internal process....?
Changing the pathname to "D:\poser\scripts\test.py" works fine.
