DamianHart opened this issue on Jan 30, 2021 ยท 8 posts
DamianHart posted Sat, 30 January 2021 at 3:03 PM
I don't use Poser a lot, but I upgraded my Mac Poser 11 to 12. When I get a new version I set my default scene to a naked Michael 4. So today I put Mike on the stage, put on his "naked" skin and put on his genitals. So far so good.
Then as I set about trying to put everything in his/my default pose, I could not get the parameter dials to work. I could select the body part I wanted, but when I tried to use the dials to dial a setting...the dials don't move.
Did something change about the process that I'm missing? Or is this a bug? User error?
Thanks!
LeeMoon posted Sat, 30 January 2021 at 4:01 PM
I'm currently running a full backup on my MacBook Pro. It has several hours to go until completed.
If someone doesn't jump in and answer, I'll be installing the Poser 12 upgrade after the backup completes and will test this for you.
I do see where tburzio is using Poser 12 on their Mac. They haven't mentioned any issues with the parameter dials.
Lee
hborre posted Sat, 30 January 2021 at 4:15 PM
Reboot the software and see if that restores the dial functions. If you encounter the same problem, submit a ticket.
DamianHart posted Sat, 30 January 2021 at 8:58 PM
I did a reboot and the dials started working. I did all sorts of gyrations on Michael 4 and it seemed to go well. But...
Once I put his willie on, things went wonky. When I clicked part of the object to adjust it, the dial panel on the right didn't keep up. The top left said "M4 Genitalia Testicles" for instance, but the top of the dial window wouldn't update to the same part. Then I couldn't select parts of the model any more. And then the dials stopped working.
Maybe M4's willie is just too old...? (ug, there's a thought....)
LeeMoon posted Sat, 30 January 2021 at 9:19 PM
Ran a quick test a few minutes ago using Poser 12 and Michael 4. I haven't noticed a slow down using Michael 4 with his genitals. Seems to be working fine. This is on the 16" MacBook Pro, not on the M1 MacBook Air.
Lee
Winningbee posted Thu, 04 February 2021 at 9:11 AM
I don't think it has anything to do with genitals. It happened to me too with no genital on the screen. I stopped and restarted Poser and all went well. This has happened to me several times now. So it must be a bug.
ghostship2 posted Thu, 04 February 2021 at 11:28 PM
The snozzberries taste like snozzberries.
Y-Phil posted Fri, 05 February 2021 at 9:34 AM
ghostship2 posted at 9:34AM Fri, 05 February 2021 - #4411934
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
