Forum: MarketPlace Customers
Subject: community newsletter coupon
Nails60 opened this issue on Feb 22, 2021 ยท 5 posts
Nails60 posted Mon, 22 February 2021 at 6:43 PM
When I tried to use this I got a message that I wasnt eligible to use it, however since I received the newletter I assume I must be on the list or am I missing something?
jennblake posted Tue, 23 February 2021 at 8:43 AM
Hi.
I am seeing you do have the role. Are the items you are trying to use the coupon on listed as prime right now? That is the only reason that might prevent you from using it. Let me know. 😄
Nails60 posted Tue, 23 February 2021 at 9:10 AM
Problem sorted, I'd left a letter out of the coupon code, I normally cut and paste but the way the newsletter was formatted meant I had to copy manually!
jennblake posted Tue, 23 February 2021 at 9:18 AM
ok 😄 Glad you got it! I'll mention that to the newsletter team.
slam posted Tue, 23 February 2021 at 2:19 PM
I think I just ran into the same issue. Because the code appears as an embedded graphic rather than text, you have to type it manually and it's easy to make errors in the process (I missed out the second 'M'). Thanks, @Nails60 for identifying the problem.
