Taborton opened this issue on Mar 31, 2021 ยท 3 posts
Taborton posted Wed, 31 March 2021 at 12:04 PM
I'm working on a 2013 MacPro, 3.5 6 core, 64 GB ram, AMD FirePro D500 3 GB. I have success when rendering to preview but when I attempt to render the same 30 frames to Firefly it crashes. It may have worked once out of 15 attempts. I tried changing movie output settings to image files and it renders 2 - 3 files and crashes. The project file is 139MB. I'm working with dreamland 81 blocks. Render settings are full quality auto, use displacement maps, depth of field checked. Progressive mode. Any help would be appreciated.
Richard60 posted Wed, 31 March 2021 at 12:35 PM
If you can render to a single image with FireFly then most likely it is the progressive settings. Since you are doing an animation you are going to have to let each frame render out fully. Other then that not sure as I have used the 81 City Blocks model in several movies suing Poser 9/10 and 11.
Taborton posted Thu, 01 April 2021 at 9:24 AM
Turning off progressive did the trick, thank you Richard60!
