Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Texturing the ~100++ sub-rigs of an unhappy FBX import ?
NikKelly opened this issue on May 01, 2021 · 3 posts
NikKelly posted Sat, 01 May 2021 at 10:07 AM
I've just downloaded a budget 'fire extinguisher cart' in FBX format from a third-party site, but problem applies to other suppliers.
At import to PoserPro_11.3, model looks okay, albeit tipped 90º, but hierarchy window shows it has come apart into ~100++ models, one for each sub-rig.
A dozen at a time, I parented these to a 'place holder', was finally able to flip all of them upright together.
They all take the same texture map-set, Base = Diffuse, Emissive, Normal, Bump etc
Is there any short-cut to batch-applying these textures to those ~100++ objects ??
FWIW, I've tried converting the FBX to OBJ+MTL, but was v7.5, and either failed due 'Insufficient Parameters', lost many parts and/or emerged minus MTL. What fraction did convert had same problem with umpteen textures to apply...
Ideas ??
