Forum: Vue
Subject: Importing models from DAZ Studio
LCole opened this issue on May 22, 2021 ยท 7 posts
LCole posted Sat, 22 May 2021 at 1:23 PM
Q. Is it relatively easy to import models/textures from DAZ into Vue? I have the latest version of Vue (which I subscribe to).
(I remember that, at one time, it was such a chore that I stuck with Poser, which is very easy to import almost anything from.
martial posted Sat, 22 May 2021 at 2:07 PM
I have Vue infinite 2016 From DAZSudio , i have imported many times without problem using collada format (.dae) , sometime obj format
martial posted Sat, 22 May 2021 at 2:11 PM
After importing, you can save as . vob (save objet option) and use the objets as regular Vue objets. I have realised also that after saving it as vob you can delete the dae objet anf even the textures imported
LCole posted Sat, 22 May 2021 at 3:45 PM
Thanks for the reply!
I will look into DAZ again. I used to use it a long time ago before Vue came along.
HartyBart posted Tue, 25 May 2021 at 4:51 AM
There is a free script set for Daz Studio which works with the $50 Atangeo Balancer as your polygon decimator. This offers a streamlined script-assisted workflow to take a posed and dressed Genesis, poly-reduced, to obj. From there, into Vue and it should be light enough not to bog down the scene (even though it's Genesis). Not for close-ups obviously.
LCole posted Tue, 25 May 2021 at 1:50 PM
The number of polygons is not an issue in Vue. I have created extremely complex objects in other programs that sometime have tens of millions of polygons.
I've never encountered any problem importing any of them into Vue.
HartyBart posted Wed, 26 May 2021 at 2:40 AM
I was thinking of complex big scenes. Three war elephants and an army of Genesis 1s coming out of the mists, and meeting a band of goblins mounted on wolves. In which case I think even the best supercomputer could use some poly reduction on the scene assets. But if it's just "G8 female, standing in a courtyard, with a sword" then you're probably right.
Don't forget that Poser and Vue have always worked well together, the result of decades of partnership. Vue can still easily and perfectly import a Poser 11 scene with posed and dressed figures.
