Subject: PP2014 Content Library alternatives now that flash is dead
3dcheapskate opened this issue on May 23, 2021 ยท 11 posts
3dcheapskate posted Sun, 23 May 2021 at 9:02 PM
(This is a follow on from Subject: Since there's no forum for pre-Poser 11 versions I'll ask here...)
I'm now getting this when I open PP2014:..
...because (I believe) Flash is now dead.
One alternative is to edit the Poser.ini file to use the built-in non-flash library (details in that other thread).
Another is to use a third party content library. Ideally a free one. Does anybody use P3DO Free from Senosoft ? Or have any other suggestions ?
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
RedPhantom posted Sun, 23 May 2021 at 9:57 PM Site Admin
https://www.renderosity.com/rr/mod/bcs/xl---content-library-for-poser/88878 was recommended by someone. I've never used it so I can't say anything about it. There is a thread here that might have more suggestions
hborre posted Sun, 23 May 2021 at 10:15 PM
If you don't mind having a free, undocked library then that is the way to go. It works well if you have a multi-monitor system, otherwise, you may want to use an alternative. But it will be similar to having the undocked library.
noxiart posted Sun, 23 May 2021 at 11:16 PM
Here's my PP-2014 UI:
And my "Flash-less" Air - library:
I'm using the floating AIR library since literally forever. Really couldn't imagine working with anything else.
noxiart posted Sun, 23 May 2021 at 11:29 PM
BTW, I could remember wrong, but wasn't there a problem saving certain files with those 3rd party librarys?
yarp posted Tue, 25 May 2021 at 3:03 AM
BTW, I could remember wrong, but wasn't there a problem saving certain files with those 3rd party librarys? Hi noxiart, this is a question I have been windering too. I recently did comparision tests of my P3DO and Poser. There were minor differences in the end files. I mean they were not identical but the differences where only related to non Figure data (like the documentation node if I recall). So I would say there is no problem. It would be true with other utilities since we are using PoserPython APi calls. The comparision is more on the abilities that those tools offer. For example with P3DO you can't select the materials for a material or save a partial pose. But I much prefer saving with P3DO. Takes far less time to save my poses than saving with Poser and more reliable (and don't have empty poses like I frequently have with Poser).
Yarp - author of P3DO Organizer for Poser
yarp posted Tue, 25 May 2021 at 4:01 AM
Based on my own experience of using both I can make an honest comparision of the 2 save actions.
For all the rest: navigation, opening, and so forth I only use P3DO, except to replace Figures which you can't do with P3DO.
pros
Septos posted Tue, 25 May 2021 at 8:24 AM
It would be important having an Extension when, if , using an external library that is taking access to the
    >AppData>Roaming>Poser??>Nr.??>LibraryPrefs.xml file
giving the option in that document to add and remove runtimes into the specific Poser versions
by changing the lines after the <LibraryPreferences in the txt any external runtime could be added through a specific external Library application.
It also can be done manually but for most it is difficult to understand how the lines need to be added.
Septos posted Tue, 25 May 2021 at 8:45 AM
SW Library Manager 2 is one of the best addition to any previous poser, a high end solution that gives the basic features of the integrated library and a huge load of additional features. it does not have the option to add a external runtime . guess SW forgot to add this into the Library manager options.
It might not work in Poser 11.2 up due the changes made on Pyton by bondware
hborre posted Tue, 25 May 2021 at 6:01 PM
Python did not absolutely change until Poser 12, all script written before then still works in P11 with the exception of a handful of applications. Most of those were corrected with AVfix.
Cage posted Sat, 29 May 2021 at 11:09 PM
Offline installers for old versions of Flash are available at archive.org. I don't know whether they could be used to restore functionality for Poser's purposes, but I know they are used that way for various other problems.
