Forum: Poser 12
Subject: Rigged clothing item disappears if I use the original obj file...
blackbonner opened this issue on Jun 05, 2021 ยท 7 posts
blackbonner posted Sat, 05 June 2021 at 4:10 AM
Last week I modelled a dress for V4. After it went through the fitting room, I saved the rigged character to my library. In the preference tab under I disabled file compression to force poser to create a obj file instead of a obz file. This worked perfectly well. Next I opened the cr2 file with an text editor and changed the path to the original obj file. If I load the clothing item from my library, the name of the item shows in the figures tab, but the geometry does not show in the viewport. What I'm doing wrong? Any help would be much appreciated!
