Forum: DAZ|Studio
Subject: Does anyone know how to fix breast?
Cyberdene opened this issue on Jun 06, 2021 ยท 6 posts
Cyberdene posted Sun, 06 June 2021 at 2:55 AM
I tried everything and I can't seem to correct this where the breast looks like they are really sagging underneath clothing. It gives this awful crinkled look Out of The Shadows Part 1.png
Razor42 posted Sun, 06 June 2021 at 8:15 PM
Sickleyield has a few Breast Helper products that may help solve this. Otherwise you could export the top as is to a 3D modeler, smooth the area then it import back into DS as a custom morph, apply and render.
JPayne posted Mon, 07 June 2021 at 11:29 AM
Or you could go to Edit> Figure> Geometry> Add smoothing modifier.... Of course, you need to select the clothes, in your case the entire shirt first. Then go into the parameters of the shirt and choose smoothing iterations to adjust the smoothing effect.
dbwalton posted Wed, 09 June 2021 at 12:24 PM
The "natural" slider causes them to sag. Reduce it. Also, play around with the diameter slider too.
I often spend HOURS fixing breasts of canned characters. There are few add on breast morphs out there, but I find I mostly use the G8F sliders that come stock with Genesis 8.
I've never tried the previously mentioned methods, but I will now. But, most of the time, the sliders do the trick for me.
Cyberdene posted Tue, 15 June 2021 at 10:35 PM
JPayne posted at 10:34PM Tue, 15 June 2021 - #4420777
Or you could go to Edit> Figure> Geometry> Add smoothing modifier.... Of course, you need to select the clothes, in your case the entire shirt first. Then go into the parameters of the shirt and choose smoothing iterations to adjust the smoothing effect. Thanks so much for telling me this, I never crank up the smoother too high but when I did, it fixed that awful sag look. I appreciate the help a lot.
dbwalton posted Fri, 18 June 2021 at 6:39 PM
Thanks Cyberdene! I just added that to an outfit with a poke through and it fixed it without doing anything else!!!
I will be using this a lot.
