Subject: Removing all bump maps from a scene
Doc000 opened this issue on Jun 14, 2021 ยท 1 posts
Doc000 posted Mon, 14 June 2021 at 1:27 PM
I'm curious if there's a way, either via script or pose file to remove all bump maps from a scene. Or something that will set them all to set them all to zero or disconnect them. I know you can uncheck "Use Displacement Maps" with Firefly, but Poser will still use any bump maps if they're attached.
I use the Scene Fixer script for many things, which saves a whole lot of time. But the one thing it doesn't do is turn off bumps.
Any suggestions would be appreciated.
