MistyLaraCarrara opened this issue on Jul 09, 2021 ยท 19 posts
MistyLaraCarrara posted Fri, 09 July 2021 at 4:42 PM
sometimes i can't remember where something is, more often these days, doh.
sharing here some quick reminder screenshots.
Objects
Shaders
Effects
To copy carrara browser tray to a new pc
copy over the preferences.txt file
this the win10 path to preference files
C:Usersyour windows10 user nameAppDataRoamingDAZ 3DCarrara 8.5
preferences.txt
somebody haz a mac path screenshot??
MistyLaraCarrara posted Fri, 09 July 2021 at 5:05 PM
Sometimes the DS Library doesn't find the .ds file, even though it's there.
sometimes deleting the DS library and re-adding doesn't fix it.
deleting the ds library thru the browser tray leaves a remnant in the preferences.txt file.
Can be anually deleted, so as to re-add it fresh and new.
open preferences.txt in a notepad editor.
look for the following lines and delete them
Look for AFOL and DSLib, delete it and the 3 lines under it.
Editing this file, can
for the subfolders, delete the index file and re-index from the browser tray.
for the top folders, manually reorder the folders in the preferences txt file.
MistyLaraCarrara posted Fri, 09 July 2021 at 5:27 PM
other things i brain fart on
MistyLaraCarrara posted Fri, 09 July 2021 at 5:34 PM
MistyLaraCarrara posted Fri, 09 July 2021 at 5:39 PM
stuck in the hair decision making process, doh, which way to go?
dyanmic hair should have a dedicated thread, by someone wo knows how to use it, lol
got so many furless furr babies
MistyLaraCarrara posted Fri, 09 July 2021 at 5:43 PM
sometimes my brain just refuses remember where the render alpha channel is.
its 2nd tab under render settings. >.<
MistyLaraCarrara posted Fri, 09 July 2021 at 6:04 PM
MistyLaraCarrara posted Fri, 09 July 2021 at 6:29 PM
Modifiers, Physics --> Soft Body, Soft Body Attached
Physical Properties
MistyLaraCarrara posted Fri, 09 July 2021 at 6:32 PM
Web dings reference for the Text Primitive
MistyLaraCarrara posted Fri, 09 July 2021 at 6:38 PM
MistyLaraCarrara posted Fri, 09 July 2021 at 6:40 PM
ROYGBIV RGB ref
MistyLaraCarrara posted Fri, 09 July 2021 at 6:47 PM
These tools I've ignored, cuz i don't know how to use em, it draws on the preview ball
Oval layer
Polygon Layer, rectangle layer
MistyLaraCarrara posted Fri, 09 July 2021 at 6:48 PM
Bones Influence.
MistyLaraCarrara posted Fri, 09 July 2021 at 6:54 PM
On the edit menu
MistyLaraCarrara posted Fri, 09 July 2021 at 6:56 PM
DS screenshot,
Converting rigging General to Blended Weight or Triax
Edit, Figure, Rigging, Concverrt ...
MistyLaraCarrara posted Fri, 09 July 2021 at 7:00 PM
Gradient Shader
i forget where to find it
MistyLaraCarrara posted Fri, 09 July 2021 at 7:12 PM
Barn Doors
MistyLaraCarrara posted Fri, 09 July 2021 at 7:16 PM
setting a shadow map
MistyLaraCarrara posted Mon, 12 July 2021 at 8:15 AM
trivia do you know where to find the lens flare?
