Fri, Nov 29, 1:59 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
Forum Moderators: Anim8dtoon, RedPhantom, Staff
New Poser Users Help F.A.Q (Last Updated: 2024 Nov 29 12:06 am)
New to Poser? Ask questions here for expert help!
Subject: OBJ
vampchild ( ) posted Sat, 24 July 2021 at 7:10 AM · edited Wed, 20 November 2024 at 4:46 PM
Can a obj prop be used in poser ?
Beware-The Smoking Man Still Lives!
vampchild ( ) posted Sat, 24 July 2021 at 7:15 AM
Never mind I found it can be used
HartyBart ( ) posted Sun, 25 July 2021 at 2:00 AM
Yes, it's done by File - Import - Wavefront OBJ. There are various things to consider for an OBJ to import to Poser.
For instance, there is usually an accompanying MTL file that tells the OBJ where its materials are. If this is present and you open it with a plain text editor - such as Notepad (Windows) or TextMate (Mac) - you'll get an idea about what this does and where it it trying to find the materials.
Another key consideration is the scaling. This is usually a matter of trial and error. If the OBJ is too small or to big, just try again with a different scaling - the default is 100.00 for a Poser import and it's easy to set. You are prompted to input a scaling level each time the OBJ imports.
Finally, there's the UV - which basically refers to how the object's material gets mapped into the 3D mesh. This is a whole art in itself, and if the UV mapping is messed up, newbies will likely not be able to fix it on their own. This is especially the case where there are 'transmaps' present.
ShaneNewville ( ) posted Sun, 22 August 2021 at 11:12 PM · edited Sun, 22 August 2021 at 11:13 PM
I just worked on a project where I had to have the scaling correct. One of the Poser peeps let me know if we export the obj from Blender using a scale (on export settings in Blender) of 0.381493011 it should match up without altering the Poser import scale settings when its brought in.. For my own workflow I needed to have the proper sizes WITHOUT altering the scale after Importing to Poser, because I needed to send my animation work back to Blender via FBX. As long as the scale was accurate from the start everything still matched up when the FBX from Poser was imported back to Blender.
Everything I work on is OBJ from Blender imported to Poser. It works well.
_____________________________
My most recent Poser animation:
Previs Dummies 2
