infinity10 opened this issue on Aug 05, 2021 ยท 11 posts
infinity10 posted Thu, 05 August 2021 at 5:22 AM
Your neigbourhood BJD person is back with another home-cooked doll. I want to show how I used Poser to complete the creation of a pose-able Ball Jointed Doll (it is not 100 per cent real !).
First I show you the results:
Eternal Hobbyist
infinity10 posted Thu, 05 August 2021 at 5:24 AM
Yes, you are correct ! This is a pose-able hierarchy of parented props.
I generated a BJD using Terawell Design Doll software.
Then I imported the OBJ (Design Doll only exports OBJ at this time) into Shade3D software in order to re-oreganise the geometry into actual dall parts. (You can probably do this with Blender3D as well, but I am more familiar with the with the process in Shade3D).
Eternal Hobbyist
infinity10 posted Thu, 05 August 2021 at 5:26 AM
I leave the re-organised Doll geometry as parts as I export the entire group. This is important because later, when I import into Poser, I get only one mesh but the groupings are all done.
Eternal Hobbyist
infinity10 posted Thu, 05 August 2021 at 5:31 AM
I proceed to change the Joint Parameter settings and adjusting x,y,z translations as I need to. Working with front, side, top and back cameras is recommended.
I find it easier to take screen captures of my adjustments made for upper and lower limbs of one side of the Doll, then using these images to apply the settings to the limbs on the other side of the Doll. Of course, the x values will be inverted (ie, 0.001 becomes =0.001 for example)
I test the rotations of the parts and fine-tune accordingly. Some parts - for example the head and the Feet - need minor translation adjustments when posed, but these are not a big deal.
I also locked some rotations to prevent un-natural poses for the limbs.
Eternal Hobbyist
infinity10 posted Thu, 05 August 2021 at 5:33 AM
The key point is to make the Joint Parameter Centre and End Points coincident (i.e. sharing the same values).
Here is an example to show what I mean:
Eternal Hobbyist
infinity10 posted Thu, 05 August 2021 at 5:34 AM
Hope this thread has been helpful in showing how Poser 12 is actually quite a fun and useful software.
Eternal Hobbyist
infinity10 posted Fri, 06 August 2021 at 4:14 AM
I went a did the female Real BJD 2021 verssion:
Eternal Hobbyist
infinity10 posted Fri, 06 August 2021 at 4:15 AM
I could also generate different hand props in different poses... Good to have that Design Doll software to work with Poser.
Eternal Hobbyist
NikKelly posted Thu, 16 September 2021 at 11:37 PM
Thank you for showing your workflow, duly book-marked.
Up to now, DaD's "Box Man" was my limit, on a good day...
TaishoBee posted Tue, 12 October 2021 at 8:15 PM
Wow amazing, I wish you could distribute her!
Poser Pro 11 (always updated to current version available) . Laptop Specs: Intel Core i7-7700 CPU @ 3.60GHz 3.60 GHz :: 16 GB Ram :: Windows 10 Pro
infinity10 posted Wed, 13 October 2021 at 11:41 PM
