magnet opened this issue on May 16, 2001 ยท 9 posts
magnet posted Wed, 16 May 2001 at 1:16 PM
Hi, How do you create custom *.rsr files, so that thumbnails for clothing look nicer? Thanks! Magnet
SAMS3D posted Wed, 16 May 2001 at 1:25 PM
Attached Link: http://www.sams3d.com
Take what ever object you have up on the screen, render it the way you like and position it the way you like, click on one of your libraries, and click the plus symbol at the bottom of the library. SCmagnet posted Wed, 16 May 2001 at 1:48 PM
Thank you, I have tried this but in the instance of doing so with clothing, it only saves the image pre-rendered, so unfortunately the thumbnails with show translucent body parts due to my texure mapping.
Eowyn posted Wed, 16 May 2001 at 1:52 PM
magnet, here's a trick I learned here in the forum... Render your image the way you want... then copy the image and paste it on to the background... Have the figure you want to save in the library selected, and move the camera so that only the background image shows and THEN save the figure. Voila! :)
thgeisel posted Wed, 16 May 2001 at 1:55 PM
There is a programm called p3doexplorer , shpuld be in freestuff with which one can do it.you can choose a pic from a paitprogramm( some you rendered before or anthoer) and use it.programm should be under utilities!
SAMS3D posted Wed, 16 May 2001 at 1:56 PM
Nice trick, I will have to try that one. SC
magnet posted Wed, 16 May 2001 at 1:59 PM
Hey, thanks! Much appreciated.
Jaager posted Wed, 16 May 2001 at 2:37 PM
Attached Link: http://http://www.renderosity.com/freestuff.ez?Topsectionid=1&Sectionid=6
You can use Harper's little RSR convert program to do it. Render the picture your want as a square and save it as a PICT file. Resize it to 91x91 and the program will convert it to an RSR for you. PP8 does not know from *.PIC but PSP does, Painter6 does and I bet PS does. I guess you could always save it out of Poser 91x91, but I think the directions suggest ~ 400x400 and then resize. maybe so you could do a composite if you wish.steveshanks posted Wed, 16 May 2001 at 2:54 PM
heres a tutorial http://interneteye3d.com/Tutorials/2001/Feb/PoserThumbs/default.asp Steve
