ajmarti opened this issue on Aug 13, 2021 ยท 17 posts
ajmarti posted Fri, 13 August 2021 at 10:50 AM
Hi guys I own Poser 11 already. but I got a new iMac so I'm thinking of gettin POSER 12... Does it worth it? Or should I stay with POSER 11? Please give me your opinion.. I've seen some people having problems with 12 version
Thanks!
Artist @ajmarti.com
emjay247 posted Fri, 13 August 2021 at 11:50 AM
I'm on a Mac and like Poser 11.3 for the python functionality (Daz DSON Importer, Reality, etc). I am considering Poser 12 to render scenes setup in 11 while I continue to work in 11. Superfly rendering is claimed to be much faster in 12, so that could be a good combination.
randym77 posted Fri, 13 August 2021 at 11:57 AM
You can try before you buy! There's a free 21 day trial.
https://www.posersoftware.com/downloads
Whether it's worth it depends on what you use Poser for. It renders in Superfly much faster, so if you use Superfly, it's probably worth it.
OTOH, there are drawbacks. A lot of Python scripts that work in older versions of Poser don't work in Poser 12. (Python 2 reached its end of life, meaning Poser 12 had to use Python 3.) Some older scripts are being converted, but not all. The simple tab in the Material Room is gone, so if you used that, you might miss it. There are a few bugs they are still working on.
You can keep both Poser 11 and 12 at the same time, and they will open each other's files, so you can have both if you want. (That's what I do.)
ajmarti posted Fri, 13 August 2021 at 12:51 PM
Thank you so much Randym77! I really appreciate your help! Yes, your observations are enough... I think ill stay with 11 for a while
Artist @ajmarti.com
RedPhantom posted Fri, 13 August 2021 at 12:56 PM Online Now! Site Admin
There is a list of some changes on the purchase page here
These are some changes that might not be listed there
Removal of combine figure, find unseen polygons and reduce poligons, Path Palette from figure menu
Removal of Path Palette from object menu
Removal of path palette, keyframe category list from windows menu
Update python to version 3
Remove links to websites from help menu, many of which are now closed
Faster superfly renders
Updated cycles render engine
Added denoiser
Added adaptive sampling to superfly
Added post effects to superfly
Added choice to render over background image or transparent background
Simple tab in materials room changed to assign tab. It allows you to add an mt5 material file to multiple material groups at once.
Option when switching an image in the image node, the image texture node in cycles, or the environment texture node to change the same image for all instances of the image in that material group, any material for that figure, or for the entire scene.
Updated nodes for updated cycles.
Added principled bsdf and prinsipledhair bsdf nodes
Improved search function in library
Search Renderosity and Posersoftware stores from library
Purchases tab includes content and purchases from Posersoftware as well as Renderosity marketplace. It is not required to use this, but it is available.
Some of these might be duplicates of the market place listing. I didn't compare my list with it too closely.
As randym77 said, there is a 21 day trail you can chack it out and see if the changes are for you.
TwiztidKidd posted Fri, 13 August 2021 at 3:29 PM
You can also enter one of the Renderosity contests for chances to win your own copy of Poser 12.
HartyBart posted Fri, 13 August 2021 at 7:25 PM
If you need scripts and non-photoreal, Poser 11. If you want the latest-greatest-fastest photoreal on your latest-greatest-fastest graphics card (and don't care about scripts), then Poser 12. But as others have said, they should work together on the same PC. Bear in mind also that Poser 12 is still in Early Access, which means you should be wary about relying on for a major new project. Things break, get fixed, break again.
HartyBart posted Fri, 13 August 2021 at 7:30 PM
emjay247 - I thought DSON died with the Smith Micro versions of Poser, due to the Python upgrade from 2.7.1 to 2.7.17. How do you have DSON import running on Poser 11.3? Did perhaps the Mac version of 11.3 not get the Python upgrade that Windows got?
hborre posted Fri, 13 August 2021 at 7:43 PM Online Now!
DSON continues to work with the latest iteration of P11, it has and will work until the software is completely decommissioned. Why else do you see Genesis figures appearing in P12, resave the figure back into the Library in P11, and reload it in P12.
HartyBart posted Fri, 13 August 2021 at 8:29 PM
Ah, thanks. Great. Fantastic news for all Poser 11 users, then.
primorge posted Fri, 13 August 2021 at 8:38 PM
"Added principled bsdf and prinsipledhair bsdf nodes"
The only reason I would buy 12 at this time.
tomyee posted Fri, 13 August 2021 at 10:23 PM
RedPhantom posted at 10:21PM Fri, 13 August 2021 - #4425223
What?!? They removed Combine Figure and Reduce Polygons? Why? Those features would be the only reason I would ever upgrade (I certainly would never use Poser 12 now knowing this, maybe Poser 11 if that's the last version that will support these features).
ssgbryan posted Sat, 14 August 2021 at 12:27 PM
Get the upgrade, keep Poser 11 as a helper app.
I have both (and a copy of Poser 7 - need it for a couple of netherworks products), as well as a copy of DS (for getting content out of DS).
RobZhena posted Mon, 16 August 2021 at 3:14 PM
Only consider Poser 12 if you work mainly with Superfly. That is the main advantage.
A_Sunbeam posted Mon, 16 August 2021 at 3:27 PM Online Now!
Depends on the OS. I have Mojave and Poser 12 will not work with it; you have to have Catalina or higher. So I stay with 11.3 ...
ajmarti posted Tue, 17 August 2021 at 11:07 AM
I have Big Sur... I think I'll stay with Poser 11 for a while. I don't need Superfly. Besides, it's too slow for me THANK YOU SO MUCH for your help GUYS!!!!
Artist @ajmarti.com
ajmarti posted Tue, 17 August 2021 at 11:09 AM
RedPhantom posted at 11:08AM Tue, 17 August 2021 - #4425223
Added denoiser
THANK YOU !!
Artist @ajmarti.com
