lynde opened this issue on May 16, 2001 ยท 4 posts
lynde posted Wed, 16 May 2001 at 2:53 PM
Hi all, I just got the upgrade for Vicki 2 and I was wondering if any of you had any trouble getting the eyebrows and eyelashes to work or if any of you might have any suggestions for what i could do differently...when it renders everything comes out perfect except for those 2 things, the lashes won't show up at all and the eyebrows end up looking like little strips of plastic over her eyes...I went to their FAQ page and read about how to fix it if it happens with the P4 model...it says to change the colors to white and select the bump, transparency and texture maps manually for those parts and it should fix it but it didnt' change at all for me plus this was happening with the regular version and not the P4 version....anyway, I'm jsut wondering if anyone else knows of something else I could try since I would really like to start working with this model now that i have it..:) hugs to all Lynde
steveshanks posted Wed, 16 May 2001 at 3:42 PM
make the upper eyebrows fully transparent and add a lash transmap to the first eyelash material that'll fix her :o).....Steve
Ghostofmacbeth posted Wed, 16 May 2001 at 6:02 PM
If you have a map with the eyebrow you can load that in too and be set ...S
lynde posted Thu, 17 May 2001 at 10:10 AM
thanks alot to both you for your kind suggestions but unfortunately this didn't seem to solve the problem (...the eyelashes are still invisible and the eyebrows are a little better but the still look sort of like they are glued on...I included an image of it...don't know if it will help but I thought I'd at least show everyone what I meant..:) hugs to all
