Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Poser 11 Pro Mac crashes when loading pre-assembled scenes
gerberc opened this issue on Dec 05, 2021 ยท 3 posts
gerberc posted Sun, 05 December 2021 at 7:25 AM
Hi everybody
I have the issue Poser 11 Pro Mac crashes when I want to load older and complex prefab scenes from the character or prop libraries.
The problem typically occurs with prop or character sets built of multiple objects. For example, I can load each individual prop of the Planet Iridia set by Petipet but not the character file with the whole, pre-assembled setting. It's not a problem specific to this product, the same happens with other sets, too. However, not all oder pre-assembled prop sets crash. There are examples like Greek&Jungle ruins that load just fine. Interestingly there is no issue with loading PZ3 files with many characters and props, both old and new ones. It just happens with some older cr2 and pz2 files from the library.
If that helps I run Poser 11 Pro on a MacBook Air with a 1.2 GHz Intel Core i7 and 16 GB RAM. However, I'm sure the problem is not related to the hardware as I had the same issue on my old MacBook Pro ...
For the time being I assemble all scenes by manually loading each prop or character individually. However it would be nice to uses pre-assembled scenes form the prop and character libraries too!
Thank you very much for any hint, Christoph
