Subject: Help with the eyes
giotim opened this issue on Jan 11, 2022 ยท 6 posts
giotim posted Tue, 11 January 2022 at 1:21 AM
Hi to everyone,
i have this little problem, i'm working on Poser Pro 2014, on a Michael 4 character (with Morph), i want to make the eyes wider, so i go to the head and work on the "EyesWidth" regulator.
And it's ok, the eyes go wider, but only the holes of the face, the eyeballs remain there, they don't follow the holes that now are wider.
I click on the eyeballs but there is no "translation" option that can help me in move them.
what i have to do?
Thank you.
Y-Phil posted Tue, 11 January 2022 at 1:36 AM
undefined posted at 1:21 AM Tue, 11 January 2022 - #2968145
Hi to everyone,
what i have to do?
Thank you.
They may be set as "Hidden parameters". The following screen caps are from Poser12, but you should find the same in your Poser version:
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟ Nas 10TB
giotim posted Tue, 11 January 2022 at 2:20 AM
Y-Phil posted at 1:36 AM Tue, 11 January 2022 - #4433097
Hi to everyone,
what i have to do?
Thank you.
Hi Phil, you're right, they appeared the axis translate options, i didn't know this thing.
Now the problem is that if i click on the various "xTranslate" modifier, and i try to move the eyeballs in the axis, they remain blocked, with the number level blocked, did you know why?
Y-Phil posted Tue, 11 January 2022 at 2:35 AM
For each parameter, you may open the corresponding dialog box:
At this point, you may have different situations:
* for exemple Min limit = Max limit, avoiding any change of the Value parameter (which is the one that's directly changed)
* sometimes, the Sensitivity is set to a very low value so that when you turn the corresponding control:
it doesn't seem to move
You may also uncheck "Hidden" so that it remains visible in your Poser file.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
giotim posted Tue, 11 January 2022 at 5:06 AM
Y-Phil posted at 2:35 AM Tue, 11 January 2022 - #4433101
Solved!
It was because of the "Force Limits" thing, without it the eyeballs started to move on their axis.
Thank you very much Phil, you saved me!
Y-Phil posted Tue, 11 January 2022 at 8:09 AM
giotim posted at 5:06 AM Tue, 11 January 2022 - #4433103
Solved!
You're welcome ๐Ÿ˜
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
