Uncanny_Film opened this issue on Feb 10, 2022 ยท 10 posts
Uncanny_Film posted Thu, 10 February 2022 at 1:15 PM
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render | Real-Flow | 3DCoat | Speed Tree | Adobe Premiere | Adobe After Effects | Adobe Audition | Adobe Photoshop
FVerbaas posted Mon, 14 February 2022 at 3:55 PM Forum Coordinator
Sorry but it is not very clear to me what you want.
You want a script that selects say the left hand of the current figure?
Once a script is in the scripts folder you can assign a shortcut to it via the shortcut editor:
FVerbaas posted Mon, 14 February 2022 at 4:26 PM Forum Coordinator
for a script to call think of something like:
Sure it could be condensed further but with this layout I hope the proces is more clear.
Uncanny_Film posted Tue, 15 February 2022 at 12:09 PM
Sorry for not being specific. Here is a link to what I'm making.
And also thank you for the example.
I'm going to use the unused keys that are in Windows but are not on a standard keyboard and set them to select and control the figure.
Here's an example of how I'm going to set the keys.
Set key F13 to select the right hand Set key F14 to move Zrotate 1 Set key F15 to move Zrotate -1
Also, the F14 and F15 will be on a rotary encoder dial, not actual keys or buttons.
I hope all this makes since
FVerbaas posted Wed, 16 February 2022 at 5:35 AM Forum Coordinator
Thank you for explaining. I see you have some excellent examples already from a previous version.
Is there anything i can still help you with?
Uncanny_Film posted Wed, 16 February 2022 at 3:34 PM
Yes, If I have a script for each command. Let's say 20. So in total, I will have 20 scripts and poser. Is there a way to set those scripts shortcuts quickly? Or will I have to still put in the script shortcut individually? One by one.Thank you for explaining. I see you have some excellent examples already from a previous version.
FVerbaas posted Wed, 16 February 2022 at 4:10 PM Forum Coordinator
The links may be in some file somewhere and you may be able to hack it but I think it will be hard to beat double-clicking the line and making the shortcut combination in the editor.
Uncanny_Film posted Mon, 21 February 2022 at 4:12 PM
FVerbaas posted Fri, 25 February 2022 at 12:37 PM Forum Coordinator
You may want to try the below.
I have set the increment to 15 degrees: (par.SetValue(val+15.0) so you see more easily the effect. Trust you can change this to your liking.
note this approach does not respect limits.
sc = poser.Scene()
try:
act = sc.CurrentActor()
try:
par = act.Parameter('yRotate')
try:
val = par.Value()
sc.DrawAll()
except:
pass
except:
pass
except:
pass
Uncanny_Film posted Tue, 15 March 2022 at 1:29 PM
note this approach does not respect limits.sc = poser.Scene()
try:
try:
try:
val = par.Value()
sc.DrawAll()
except:
pass
except:
pass
except:
pass
Thank you. this is perfect.
Is there a document with all the python script command that poser uses?
