DocMatter opened this issue on Feb 17, 2022 ยท 12 posts
DocMatter posted Thu, 17 February 2022 at 10:08 AM
I found a scene here that I really want to use in Poser 12, but it's made for Daz Studio (all textures in iRay).
It's a fairly complex scene (lots of different textures), but nothing I can't find replacements for in me various Superfly material folders. Is it doable?
I know the other option is to just use it in Studio, but I'm just learning it and all the existing figures I want to use (V4 and M4) are ready to go in Poser.
randym77 posted Thu, 17 February 2022 at 11:57 AM
It's doable, but there will be hoops to jump through. I've heard good things about this script:
https://www.renderosity.com/rr/mod/bcs/duf-prop-converter-for-poser-12/153019/
What scene is it?
hborre posted Thu, 17 February 2022 at 12:01 PM
It's a matter of how well the set converts over to Poser. Since there is no existing app that can conveniently do the conversion with the exception of Ken1171_Designs DUF Prop Converter for Poser 12, you would need to manually convert the files between DS and Poser. And to get similar render results, you may need to heavily use the Cycle nodes instead of the PoserSurface node. You're talking major workflow time.
DocMatter posted Thu, 17 February 2022 at 12:20 PM
Its the Back Alley scene and add-ons by Christophe3D.It's doable, but there will be hoops to jump through. I've heard good things about this script:
What scene is it?
DocMatter posted Thu, 17 February 2022 at 12:22 PM
The script looks like it might work, but I'm on a Mac and the last I heard, scripts aren't working in Poser12 for Macs yet. Hopefully I'm wrong.
RedPhantom posted Thu, 17 February 2022 at 2:57 PM Site Admin
If the script isn't working, you can export it from Daz studio as an obj (or a few if you want separate pieces) and then import them into poser. It's a bit of a pain, but doable. I just did a scene with Aslan court, because the room was so close to what I was picturing, I think the creator may have been reading my mind.
DocMatter posted Thu, 17 February 2022 at 5:20 PM
I think I'm going to take the plunge and try and use it in Studio. I was reluctant to go this route because it seems I have to recreate all my saved figures (V4 and M4 with textures and morphs) in Studio if I want them to look right.
Thanks for everyone's suggestions!
NikKelly posted Thu, 03 March 2022 at 7:56 PM
As DSF Tools ($$) seems to run very slow for files larger than 1~~2 MB, I figured how to use DS' own tools.
Free tutorial, not optimised but works okay...
https://www.deviantart.com/nik-2213/art/Porting-DAZ-Studio-props-to-Poser-friendly-OBJ-MTL-899045469
This is especially useful when object has many textures, as DSF Tools only exports bare OBJ, without MTL...
Y-Phil posted Fri, 04 March 2022 at 1:45 AM
Just in case: this is a villa from Stonemason, imported form DS using the FBX format. True evidence: the mats need to be rebuild but I don't care as I can use Cycles.
But sometimes, FBX moves everything at 0,0,0. I don't know why, as I'm no expert, but in these cases I can use the Collada path, such as here:
This place, too, is a DS scene, imported using the Collada format:
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
VedaDalsette posted Fri, 04 March 2022 at 2:41 PM Online Now!
You'll still want to go through all or most of the mats after using the DUF Prop Converter script, BUT it connects the diffuse texture map to the PoserSurface root node for each mat that has one. But I wish there was an option to choose to have either PoserSurface or PhysicalSurface root node. One less step.
W11,Intel i9-14900KF @ 3.20GHz, 64.0 GB RAM, 64-bit, GeForce GTX 4070 Ti SUPER, 16GB.
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
NikKelly posted Wed, 09 March 2022 at 9:30 AM
Bravo, Y-Phil !!
Y-Phil posted Wed, 09 March 2022 at 1:19 PM
Thank you NikKelly ๐Bravo, Y-Phil !!
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
