rokket opened this issue on Mar 07, 2022 · 17 posts
rokket posted Mon, 07 March 2022 at 11:15 AM
I want to use the ground to capture the shadow of my figure, and have it appear to be on the background image in EZDome.
But I can't figure out how to do it. I know I pulled it off once in Poser 8, by ticking the shadow catch only and some other thing I saw someone posted in here years back.
How would I do it in Superfly?
Here is the image I am trying to do that with.
RedPhantom posted Mon, 07 March 2022 at 11:29 AM Site Admin
Shadow catcher doesn’t work in poser 11 SF. In P12 there were issues, but I don’t remember what they were and my poser computer dies so I can’t check. If you render over a background shader rather than a sphere it works fine in the same manner as firefly.
If you want to use Ezdome it has its own shadow catcher that it can setup
rokket posted Mon, 07 March 2022 at 12:45 PM
RedPhantom posted at 11:29 AM Mon, 7 March 2022 - #4435537
I will take a look at EZDome again. I usually don't mess with any of the settings, so I will check that out.Shadow catcher doesn’t work in poser 11 SF. In P12 there were issues, but I don’t remember what they were and my poser computer dies so I can’t check. If you render over a background shader rather than a sphere it works fine in the same manner as firefly.
rokket posted Mon, 07 March 2022 at 12:56 PM
I don't see in the EZDome where I can set up shadow catcher....
hborre posted Mon, 07 March 2022 at 1:35 PM
Which version of EZDome do you have? The version that has the Shadowcatcher is 1.7.
Y-Phil posted Mon, 07 March 2022 at 1:48 PM
Just in case you need some explanations by Snarly himself: see his video.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Y-Phil posted Mon, 07 March 2022 at 2:00 PM
And just in case you'd like to use Poser12's background node, you may use a PoserSurface's "Shadow_catch_only" mode on a round ground plane, using the show settings:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
rokket posted Mon, 07 March 2022 at 3:26 PM
I am still on Poser 11, and I will check which version of EZDome that I have...
Y-Phil posted Mon, 07 March 2022 at 3:30 PM
You may check for the actual "official page" here.I am still on Poser 11, and I will check which version of EZDome that I have...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
rokket posted Mon, 07 March 2022 at 3:31 PM
All I can find is that it says it's build 49, so apparently, I have an older version?
Snarly's website is suspended in the link there, so I don't even know where to get the latest version that will work with Poser 11...
Miss B posted Mon, 07 March 2022 at 3:48 PM
Snarly's Scripts are now hosted by a fellow member, CobraBlade. You can find them here --> Snarly's Scripts
_______________
Y-Phil posted Mon, 07 March 2022 at 3:49 PM
The last versions for Poser11 and Poser12 are on cobrablade.net, precisely.All I can find is that it says it's build 49, so apparently, I have an older version?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
rokket posted Mon, 07 March 2022 at 4:57 PM
Thank you, Miss B!!!!Snarly's Scripts are now hosted by a fellow member, CobraBlade. You can find them here --> Snarly's Scripts
rokket posted Mon, 07 March 2022 at 5:03 PM
Changed the hair to what I was looking for. Now to get that shadow...
rokket posted Mon, 07 March 2022 at 11:51 PM
Those other versions of EZDome don't work in my version of Poser 11...
Damn
rokket posted Tue, 08 March 2022 at 10:17 AM
And now I have to find the version I had and reinstall it....
rokket posted Mon, 11 April 2022 at 10:37 PM
Since I can't get a shadow in my version of Poser 11, I decided I would have to do some post work to get one in there. I will have to do another render of this without the ezdome and get the shadow on the ground or use one of the planes in the primitive folder.
I changed the pose because I didn't like what her right hand was doing.
