Uncanny_Film opened this issue on Mar 25, 2022 ยท 9 posts
Uncanny_Film posted Fri, 25 March 2022 at 3:53 PM
Hello, can anybody help me locate the Keyboard shortcut file that poser saves.
I want to take a look at it because of a device I'm trying to create.
Thanks
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render | Real-Flow | 3DCoat | Speed Tree | Adobe Premiere | Adobe After Effects | Adobe Audition | Adobe Photoshop
Y-Phil posted Sat, 26 March 2022 at 12:01 PM
You should taker a look at a file named "Poser.xrc". For Poser11 as well as for Poser12: it's installed in a subfolder called "ui", under "runtime", but the "runtime" folder where your executable is lying.
The file in question looks like an XML one.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
Uncanny_Film posted Tue, 29 March 2022 at 10:33 AM
Y-Phil posted Tue, 29 March 2022 at 12:54 PM
spartan00j posted at 10:33 AM Tue, 29 March 2022 - #4436544
Y-Phil posted at 12:01 PM Sat, 26 March 2022 - #4436398It's true that the official Poser documentation is somewhat... succinct to say the least...You should taker a look at a file named "Poser.xrc". For Poser11 as well as for Poser12: it's installed in a subfolder called "ui", under "runtime", but the "runtime" folder where your executable is lying.
Thanks for pointing me in the right direction. But I cannot seem to find the shortcuts for the scripts. When I create a custom shortcut for a script I want to know it's saved location.
:smile:
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
Uncanny_Film posted Fri, 20 May 2022 at 2:41 PM
Y-Phil posted at 12:54 PM Tue, 29 March 2022 - #4436548
So basically I'm out of luck? ๐ฅบspartan00j posted at 10:33 AM Tue, 29 March 2022 - #4436544
:smile:
Y-Phil posted Sat, 21 May 2022 at 8:28 AM
I tried to add a shortcut to select the Aux Camera and the file that got changed is Accelerators.xml.
It's located in Poser's profile, which means %appdata%\Poser\12 or %appdata%\Poser Pro\11 on Windows platforms and depending on your Poser verson.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
DCArt posted Sat, 21 May 2022 at 12:45 PM
It's not an oversight in the documentation. There are no default script shortcuts in Poser (at least, there are none listed in the Keyboard Shortcuts list) which is why the category is blank in the manual. Each developer will no doubt use their own script shortcuts in each script they create, so unfortunately there is no easy way to track them all.
To see a list of all keyboard shortcuts used in Poser, choose Edit > General Preferences (or use Ctrl+E). Then select the Interface tab, and click the Edit Shortcuts button in the lower right of the General Preferences dialog. You can use that dialog to add script shortcuts that you need.
DCArt posted Sat, 21 May 2022 at 1:02 PM
I've pinged for someone on the team to take a look at this thread, in case there is a preferred location for customized shortcuts
nerd posted Sat, 21 May 2022 at 8:11 PM Forum Moderator
The user shortcuts are stored in %appdata%\Roaming\Poser\12\Accelerators.xml
If no user shortcuts have been created that file may not exist and it will only contain the shortcuts a user has created.
