Forum: DAZ|Studio
Subject: How do you use UV mapper to create new uv map map for figure?
Tucan-Tiki opened this issue on Apr 08, 2022 ยท 2 posts
Tucan-Tiki posted Fri, 08 April 2022 at 2:40 AM
How do you use UV mapper to remap a clothing item with a new UV map?
RHaseltine posted Fri, 08 April 2022 at 4:06 PM
Export the item as OBJ, at Base resolution and with no attachments (no buttons as Rigid Follow Nodes, for example).
Edit that and save as OBJ.
Back in DS, select the item and in the Surfaces pane open the option menu (the lined/hamburger button in the top corner or right-click the tab)>Load UV Set and select the modified OBJ.
If you want to make it available in all instances of the outfit, or if you want to share it, File>Save As>Support Assets>UV Asset(s) - the Author and Product fields will be used as folder names in /data/publisher/product/item/UV Sets/ if you need to find it for sharing (or backup)
