Sunfire opened this issue on Apr 19, 2022 ยท 3 posts
Sunfire posted Tue, 19 April 2022 at 4:48 PM
Hello Again!
Got another question about doing something in DAZ Studio that escapes me.
I'm wanting to create a material for an outfit that has a pattern that is more visible in direct light, and less visible where the light isn't so strong.
Like this:
Do you see how the skirt texture fades in and out based on the lighting? I'd like to do the same in DS how would I do this?
Thanks!
Sunfire
Rosseliani posted Thu, 21 April 2022 at 6:09 AM
Try to use an opacity map of the pattern and apply it to the Glossy Layered Weight, Glossy reflectivity, Metallic Flakes Weight and Top Coat Weight, then play with the Roughness / Glossiness associated parameters:
Sunfire posted Thu, 21 April 2022 at 11:49 AM
Okay, I had thought about the glossy layered weight as that is close to how it's done in Poser, couldn't get it to do quite what I wanted. I will futz with it some more and chalk it all up to learning new things through the practice of old style hack it until you get it.
