ghostship2 opened this issue on Apr 23, 2022 ยท 3 posts
ghostship2 posted Sat, 23 April 2022 at 3:13 PM
Hey folks,
Trying to use Olive hair in P12 and the prop freezes the render up for about five min on "loading actor" then renders as normal. I re-loaded the Geometry and library files to try to fix the issue but that did not help. I've never seen a hair piece do this. It does it on GPU AND CPU.
Can anyone confirm they are having the same issue with this hair?
thanks
Y-Phil posted Sat, 23 April 2022 at 5:54 PM Online Now!
Sorry but I haven't seen the freezing effect you are describing (tested using the 4 versions).
Just to be sure: the zip files have the numbers 111477 and 111478
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
Y-Phil posted Sat, 23 April 2022 at 6:11 PM Online Now!
Lol... I spoke too quickly. It freezes the way you spoke, but only if the Fit Aiko4 is set to 0. Increase it slightly and it doesn't freeze..
I've discovered this because my first test was with an aiko4 based character (Dollz Trimbel)
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
