romangirl opened this issue on May 10, 2022 ยท 3 posts
romangirl posted Tue, 10 May 2022 at 11:27 AM
I hope this is in the right place.
Yes, I confess, I have one favorite character, created from V3. I'm using Poserpro11.
Her genital area is just a white triangle where the pubic hair should go.
How can I fix that? I'm not sending an image unless you feel the need to see it.
Thank you!
hborre posted Tue, 10 May 2022 at 2:33 PM Online Now!
The current version of Poser 11 is no longer referred to as Poser Pro, the Pro part of the title has been dropped. As for your problem, it sounds like there is a color map missing or the Diffuse_Color chip is white. Have you applied any textures to V3 and, if you have, does it correct the problem? By default, the PubicHair material zone is set to transparency. Chances are that if you have a white Diffuse color and the Transparency values are set to zero you will have a white area. However, without seeing the Material Room setup for this area I'm only guessing.
romangirl posted Wed, 11 May 2022 at 3:00 PM
Thanks for your intput
