Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: What is the difference between LaFemme and LaFemme Pro base figures?
Miscreate opened this issue on May 20, 2022 ยท 6 posts
Miscreate posted Fri, 20 May 2022 at 7:04 PM
I would like to know if there is a difference between to base figures for LaFemme and LaFemme Pro - just the figures, not the packages. I have purchased the LaFemme Head Morphs package separately from the LaFemme Pro Bundle and would like to know why the readme states that I still need to have LaFemme Pro 1.1 for the product to work. If I inject the product on a base LaFemme figure using the All Morphs option, doesn't that create all the morph channels that would be available for LaFemme Pro (at least for the head/face)? Thanks.
NikKelly posted Sat, 21 May 2022 at 1:21 PM
The Pro has more / better morphs ??
FWIW, I'd like a 'lite' version of 'base' LF......
Miscreate posted Mon, 23 May 2022 at 1:18 AM
Thanks for the response, NikKelly. You are correct, LaFemme Pro does have more morphs built-in. But my question was whether the base LaFemme figure would have the same head/face morphs with the LaFemme Head Morphs package injected.
RedPhantom posted Mon, 23 May 2022 at 6:53 AM Online Now! Site Admin
Which package is it?
Miscreate posted Mon, 23 May 2022 at 5:10 PM
It is this one:
https://www.renderosity.com/rr/mod/bcs/?ViewProduct=141433
Thanks
RedPhantom posted Mon, 23 May 2022 at 6:58 PM Online Now! Site Admin
The two figures use the same obj file the bodies just load a little differently. Since these only affect the head, it would stand to reason they should work. The issue might be that they inject into the body rather than just the head. I do have them and I'm able to get the ones I tried to work in the standard Lafemme version. But I can't promise you'll get similar results. It's not one of my products. I don't know if my having the pro version installed also is affecting it. It shouldn't. Since you have them, unless you are planning on returning them, give them a try.
