Forum: DAZ|Studio
Subject: Morph Transfering...
Cobbler3D opened this issue on Jun 06, 2022 ยท 5 posts
Cobbler3D posted Mon, 06 June 2022 at 8:18 PM
Hi all,
I don't know if this is the best place to put this question but since I am a DAZ user that uses V4 Poser figures , I think I will post here.
I know of scripts that take previous Genesis and Poser characters and transfers them to the later/modern Genesis figures but is there an app out there that can transfer a V3's head morph to a V4 character?
Thanks!
RHaseltine posted Tue, 07 June 2022 at 2:15 PM
Not, that I can recall offhand, automatically - you could use a 3D editor's shrinkwrap-type feature to make the one OBJ match the shape of the other, then load that as a morph, but there would probably be a lot of adjustment required after that to get a fully-working morph.
Cobbler3D posted Tue, 07 June 2022 at 5:36 PM
Thanks Richard,
I will look into that as a solution. I've never tried using a shrinkwrap mesh overlay solution before  but if it behaves like a morph then that would be ideal. I'm disappointed there isn't a product for that already... But I guess that would be in Poser's court since it is V3->V4 after all...
Writers_Block posted Sun, 12 June 2022 at 6:25 AM
There are some V3/A3 (or whatever) shapes available on Genesis. I transfered Aiko 3 to G8F this way. I just chose a decent set of textures after that, without fewobvious blemishes or moles, which reflected the characteristics of Aiko 3's textures.
Perhaps a similar process would work in your case, presuming there is a V3 equivalent on Genesis?
Below is the shape dialled in, although not the textures I used.
They are available too:
https://www.daz3d.com/v3-and-m3-shapes-for-genesis
Cobbler3D posted Sun, 12 June 2022 at 5:45 PM
Thanks @Writersblock!
The trouble I am having is finding a solution that moves V3 morphs to V4. I use a lot of different apps and techniques to get V3 and V4 to all the Genesis characters with no problems. Short of Richard's solution, I'm thinking it will have to involve more technical modeling method to get V3 head morphs to get on to a V4 character...
