Subject: work around?
DarkElegance opened this issue on Jun 30, 2022 ยท 9 posts
DarkElegance posted Thu, 30 June 2022 at 11:46 PM
So today, after many years of it gathering dust...I decided to open my poser. 2012.
To find apparently the library doesnt work anymore? Is there a work around?
https://www.darkelegance.co.uk/
Commission Closed till 2025
JoePublic posted Fri, 01 July 2022 at 3:06 AM
Easiest workaround: Get Poser 11 while it is on sale.
Otherwise:
Switch the library from FLASH to AIR.
https://www.posersoftware.com/article/499/how-to-fix-your-runtime-now-that-adobe-flash-has-reached-end-of-life
That's how I run my PP 2014 on Windows 10.
DarkElegance posted Fri, 01 July 2022 at 6:01 AM
JoePublic posted at 3:06 AM Fri, 1 July 2022 - #4440585
Otherwise:
Thank you!! I much appreciate it
DarkElegance posted Fri, 01 July 2022 at 6:07 AM
I actually went and bought poser11. Cant knock that price. Again thanks!
Cascade777 posted Fri, 01 July 2022 at 11:38 AM
There is a Flash version that will enable the old Library in Poser Pro 2012 and  Poser Pro 2014 , actually Poser 9 and 10 if you prefer using it instead of the external Air version
Tested and running on my Win 10 21h2 version. Make sure to remove any older flash versions, actually they should be already off on most systems . Working flash version is V.11.2.202.235
you can use the Working flash version I uploaded and give it a shot ... if it works for you you might be doing a happy dance. Make sure to disable automatic updates after Install, you will be asked !
Download Working Flash Here
Cascade777 posted Fri, 01 July 2022 at 5:48 PM
I am still trying to figure out a method like the solution above for "Reality" to be working again !  The above original Flash version fixes many older apps that depend on Flash but it does not work for Reality and I have not figured out why that is, until now .
As for of those that run Poser 11.2 it sure is an option having the library without Flash but since Bondware broke the Python engine for most Pythons on there update after the original release of the Smith micro versions it might be still good having a working PP 2014 or 2012, at least for the ones who depend on Pythons or are in Possession of older bought packages that have python helpers in there setups.
Anyway if someone might have a good solution based on the above method using older Flash versions making also Reality work again it sure would be a great thing to have.
Cascade777 posted Fri, 01 July 2022 at 6:57 PM
I think I just found a workaround to run reality, just not sure how I got it to run ! Did so many changes that I have to figure out now witch of them it was, or what combination. Well at least it is possible as that render engine is great for Poser.
JoePublic posted Fri, 01 July 2022 at 7:49 PM
Thanks for the link Cascade777.
I don't have any need for Flash in Poser (anymore), but I loved playing Flash games.
I currently use Ruffle and BlueMaxima's Flashpoint for my old animations and games which stopped working on Windows 10.
I wonder if Ruffle would work with Poser, but as I said, already use the Air library. (And Poser 11)
Still good to have options!
JoePublic posted Fri, 01 July 2022 at 7:54 PM
@DarkElegance:
You're welcome and congrats. Hope you enjoy all the new goodies that come with it.
I'm overall quite happy with my purchase, too.
