Cobbler3D opened this issue on Jul 04, 2022 ยท 4 posts
Cobbler3D posted Mon, 04 July 2022 at 3:26 PM
Hi all, I'm doing the long arduous task of rebuilding the PC and its production environment after my old PC of 16 years took the permadeath to its MoBo a couple weeks ago.
After reinstalling to the newest version of DAZ Studio, the GenX pane for the 'Genesis Geration X2' morph utility went missing and it is no longer listed in my Panes section off the main menu area. When I went to the manual to see how I get it back, I encountered this:
"...In some cases, GenX might be missing in the main menu of DS4. This may happen due to
menu customization. In that case, use Edit/Customize from the main menu and add the
GenX entry on the left side under Panes to the main menu on the right side. It also helps
usually to select a different layout or reset the current layout for the workspace..."
Except there is no Edit/Customize section from the Edit Menu anymore.
Anyone with the product know how to get the pane back?
Thanks all!
RHaseltine posted Tue, 05 July 2022 at 8:01 AM
Does it require a serial numbe, probably via Help>About Installed Plug-ins? Is it listed at all in Help>About Installed Plug-ins?
Window>Workspace>Update and Merge Menus would be the command needed if that is the issue, it's been there for a while but of course the instructions are old.
Cobbler3D posted Tue, 05 July 2022 at 1:38 PM
Thanks Richard I will give the workspace a shot!
Cobbler3D posted Tue, 05 July 2022 at 1:42 PM
Looks like the merging of the menus worked, thanks again!
