Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Is there a video tutorial out there showing how to transfer a bone rig
RAMWorks opened this issue on Jul 09, 2022 ยท 3 posts
RAMWorks posted Sat, 09 July 2022 at 10:50 AM
So I made these pants for Dusk SE a while back, I created some really nice morphs for the pants and wanted to refit them over to LH.  I've had so many issues in the fitting room that I think the next step for me and Poser is to learn how to properly copy and paste LH's rig over to the pants and I'm hoping in that way I can retain the morphs.  I have them scaled and fitted to the LH shape in the form of a morph called "Refit" and have that locked so the shape is retained but the pants morphs all work as expected.
I know there is an older video on YouTube but it's not really that thorough and misses some minute points that I'll need to understand what's going on in the process.
Thanks for any help.
I'm using Poser 11 for this refit.
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
nerd posted Sat, 09 July 2022 at 7:14 PM Forum Moderator
There might be something useful in this play list:
https://www.youtube.com/watch?v=T_6dWzO5gMI&list=PLO5K0_q2d4kToFqbMhnqCTIZdDo6TGz3c
It made for Femm but the concepts are the same. The hard part may be finding a good donor for Dusk. The donor's JCM need to be plain morphs. No dependencies need to be setup. It "can" work if the donor has dependencies setup but it takes more work.
If you get stuck in JCM and them not cross talking the way they should post back. I'll get that working for you. In the long run if you're going to work with Dusk more. The best way is to make a Dev rig. That way you only have to do it once.
RAMWorks posted Sat, 09 July 2022 at 7:28 PM
Thanks Charles.  I really hope one of these days we can have a transfer utility (similar to the one DS uses) for transferring between figures.  I'll take a look at the video.  YUP, this is a vid I've seen.  I guess it makes more sense to me now as I've been tooling around for the past couple of years with Poser so it's informative and hopefully I've gained some confidence in getting this over to LH.  The concern though is that the end result is that the cloth is now NEW so wondering does this path copy the morphs over to the newly minted cloth and if not is there a quick way to copy them over to the new clothing item?
Thanks again!
Richard
My Store is HERE
