Forum: Poser 12
Subject: Rendering With No Background After You've Imported A Background...?
twelvefield opened this issue on Jul 18, 2022 ยท 5 posts
twelvefield posted Mon, 18 July 2022 at 8:22 PM
Maybe I'm missing something, but I can't figure this on my own.  I want to render a model with a transparent background, but I have imported an image as a background.
I know that I can turn the GROUND prop visibility off and set Superfly to render a Transparent Background, and the result is a .PNG with a transparent alpha layer in Photoshop: works perfect if there is no background image.
For some of my models, I've been scanning in my own artwork to use as a reference.  I put that image in the background and then I can line up the Poser model to make it match.  However, once I import a background image, I can't find a way to "unimport" it to be rid of it.  I've tried replacing the image with a transparent .PNG, but that isn't working.  My current workaround is to import a blank grey background, which is fairly easy to eliminate in Photoshop.  It would be more elegant to not have to do that, though.  The background isn't a prop, so it can't be made transparent... right?  Is there an easy fix for this?
NikKelly posted Mon, 18 July 2022 at 8:48 PM
I may have misunderstood question but, IIRC, GROUND has two materials, one for the floor, other for sky-dome...
RedPhantom posted Mon, 18 July 2022 at 9:32 PM Site Admin
go to the material room. choose the background as the object. Find the BG Color node and plug that in the color spot
DCArt posted Tue, 19 July 2022 at 12:06 PM
In Poser menu, choose Display > Clear Background Picture
RobZhena posted Sat, 23 July 2022 at 4:49 PM
I often put a background picture on a 1-sided square prop. Of course, that's easy to do in Poser 11 with the simple tab.
