Forum: Photoshop
Subject: my post
goofygrape opened this issue on Aug 13, 2022 ยท 5 posts
goofygrape posted Sat, 13 August 2022 at 4:41 PM
where did my post go??
Wolfenshire posted Sat, 13 August 2022 at 5:04 PM Online Now! Site Admin
I had to remove it, you can't post character maps/textures/images you didn't create.
Wolfenshire, Moderator/Community Leader
goofygrape posted Sat, 13 August 2022 at 9:21 PM
ok, I did not know that they were that, I paid for them so I should be able to add veins to anything I seem fit as long as I don't call them mine or sell them as that.
now answer my question, you are the photoshop person?
I'll paraphrase how do you go about adding the veins to a texture? Let's say a locomotive that I made myself or some of my own creations. I just used the G8f texture as an example
The veins were bought from somebody named AJ. some long long time ago in a faraway galaxy.
Wolfenshire posted Sun, 14 August 2022 at 12:32 AM Online Now! Site Admin
Yes, I'm one of the Photoshop Moderators, along with a few other areas.
Anyway, you can modify the textures all day long, and post the rendered image, you just can't post the product texture maps by themselves.
1. Take your skin texture map into photoshop. That will be your bottom layer.
2. Put your vein map on top of the skin texture map. That will be layer 2.
3. Set vein map to multiply and drop the opacity to 28%.
5. Apply your new skin map to your character.
6. Take a look at the results, and if needed, go back and adjust the vein map opacity.
8. Apply the new modified texture.
9. Take a look at the results, and if needed adjust again, always saving as a new file. The reason is - Daz doesn't update the texture if you keep saving over the first file, it'll just keep showing you the first version. I don't know why, and maybe there's a way to make it update, but I don't know how. I just keep saving in ascending order as I work on it; 001, 002, 003, and so on. That forces Daz to show you the newest adjusted texture.
The maps you have are super simple because they are the same size and line up perfectly. You should have a finished result in no time.
I'm sure there are a thousand different ways to do it, but this is how I would do it.
goofygrape posted Sun, 14 August 2022 at 8:02 PM
sorry for my attitude and thank you for your help
