HartyBart opened this issue on Oct 28, 2022 ยท 5 posts
HartyBart posted Fri, 28 October 2022 at 1:04 PM
I'm thinking of a "script installer", in which newly-acquired scripts are automatically copied to the ..|Runtime|Python|poserScripts|ScriptsMenu folder
This would be of use to the less advanced Poser user, who has acquired a shiny new script. In trepidation they then go hunting through Windows Explorer for ten minutes to locate the right place to paste the script(s), in order to have the scripts show up in the Poser User Interface. Maybe they get it wrong. It would be nice to automate the install.
IN POSER:
The following PoserPython script can be used to detect the install folder of the running Poser, and print the path, and could be developed as a script-installer....
HartyBart posted Sat, 29 October 2022 at 7:15 PM
Well, I wrote a basic Windows.BAT file as a starter. USE: Put it in the folder with your newly downloaded Poser 11 .PY scripts, then run it in Admin mode. It finds whatever the Windows OS is using as "Program Files", whatever drive that may be on. Then it finds there Poser 11 (whether installed to "Smith Micro" or "Poser Software") and finally it copies all the .PY files to the correct scripts folder, so they can be found when Poser is started.
adp001 posted Sun, 30 October 2022 at 2:54 PM
Why a batch file?
A user who is not able to start a script according to instructions should avoid computers. After all, this is not rocket science but absolute basic knowledge.
In general: How does the "stupid user" know how to execute a .BAT file and where to find it? If you can teach him that, then he can also find and execute a Python script.
(I generally don't think it's a good idea to counter non-knowledge with even more help. Imparting knowledge is always the better idea)
Of course I don't want to stop you from your project. I just think it is quite unnecessary.
ironsoul posted Mon, 31 October 2022 at 1:41 PM
Excellent idea, just include/drop the install file in the same directory as the python scripts and run
I always think that automation/install scripts follow a 10/90 rule where 10% of effort achives 90% of the functionality but the remaining 10% takes 90% of the time.
These are the thoughts I try to follow when automating a process like an install
1. Don't modify/delete a users existing files without their consent
2. Don't trash either the application or other peoples scripts
3. Use atomic operations where possible so its easy to revert if the script fails
4. Don't mess up the users hard drive with unnecessary files
Sure there are others, helps to be paraniod :)
Point 1 - Display files to be changed and use set /p to seek confirmation
Point 2 - More difficult, use unique file nameing conventions so less likely to overwite another persons files
Point 3 - Rename function is very powerful when building complex installs - generate new files in temp area and if all works ok at the end just rename file/directory. This is important if the program is running and may lock a file, easier a rename a directory than wind back many ops incase of a failure
Point 4 - Need to consider if version specific and also if user runs the script if no install exists
Just from a discussion point of view, Immediate thought on script is what what happens if more than one version of Poser install
For version specific installs the reg command might help (might be possibe to refine reg command line other otherwises a "for" + "findstr" might do the trick
To find current active version of Poser the "ftype" command, again I wondering if the for command can be used to pull this into an environ var
HartyBart posted Tue, 01 November 2022 at 2:43 PM
Thanks Ironsoul. Useful tips.
1. "use unique file naming conventions so less likely to overwrite another persons files" - yes, it might be useful for the .BAT to append a suffix to the copied .PY file(s). And thus prevent an overwrite if the files already exist.
2. "If user runs the script if no install exists" - yes, there should probably be an "Poser 11 not found" fallback message. That would be added, if I released it on Freestuff.
3. "what happens if more than one version of Poser install" - three versions could be supplied. It's just a matter of changing the "Poser 11" wording to Poser 12 or Poser 2014. An advanced user would do that, but it would be easier to supply three files each marked as _P11, _P12, _P2014.
4. Yes I thought of searching the Windows registry, but I wasn't sure what souped-up level of security paranoia level Windows 10 and 11 have for that. The above .BAT file handles the search quickly - and without need for a wildcard to detect either "Smith Micro" or "Poser Software" in the path - by splitting and then rejoining the Program Files path.
