bdpoppa opened this issue on Dec 05, 2022 ยท 3 posts
bdpoppa posted Mon, 05 December 2022 at 4:13 PM
I accidentally messed up the Material Room and tried everything to get it back to the original scene. (I can't seem to get the elements to stay where I want them. Every time I add the material element the main scene drops to the bottom and won't move. Just a matter of not knowing the proper method) Relaunching in Factory scene mode has no effect. I remember and old posting about a file somewhere that can be deleted or renamed to reset the scenes. Possible under users/name? Any help would be greatly appreciated!
bdpoppa posted Mon, 05 December 2022 at 4:37 PM
I found it !! Under the preferences I changed
the launch to Factory instead of Previous.
nerd posted Mon, 05 December 2022 at 6:07 PM Forum Moderator
For future reference when you get your UI set the way you like it set a UI dot for each room as you get it arrange the way you like. I personally use several different UI layouts depending on what I'm doing.
