rokket opened this issue on Dec 28, 2022 ยท 8 posts
rokket posted Wed, 28 December 2022 at 9:45 AM
Where can I download another copy of the Poser 11 Pro runtime? I made some very stupid errors when I was installing that behemoth and I need a do over...
donnena posted Wed, 28 December 2022 at 10:26 AM
rokket posted Wed, 28 December 2022 at 10:34 AM
Thank you! I found it right before you posted. I started downloading, but I am at work and the bandwidth is being shared with about 4000 people. I might give up after the first four files and just finish at home!
rokket posted Thu, 29 December 2022 at 8:17 AM
I wish there was still an installer for all this stuff. I am not sure how to unzip it into a runtime...
hborre posted Thu, 29 December 2022 at 9:12 AM Online Now!
You can use Poser's native installer but it doesn't do the batch installation nor distinguish between which runtime folders you want to unzip. I agree it's a tedious process and you can wind up with duplicate files if you don't keep track.
rokket posted Thu, 29 December 2022 at 9:12 AM
I figured it out. You can do it inside Poser 11 by selecting install from zip file...
hborre posted Thu, 29 December 2022 at 9:15 AM Online Now!
Pet peeve, double-check that all the zip files are consistent and in the same hierarchy structure, otherwise you will have folders either nested within runtime folders or completely outside runtime folders.
rokket posted Fri, 30 December 2022 at 10:03 AM
I got everything installed.
How do I clean up duplicates, though?
