phil_lawson opened this issue on Dec 31, 2022 ยท 9 posts
phil_lawson posted Sat, 31 December 2022 at 5:08 AM
Anyone know how I can make the Raytrace Preview (Under the Window - Raytrace Preview menu) a bit bigger? Its too small for my old tired eyes. I've looked under the preferences but there's nothing there. I'm on Poser 10 (still)..
hborre posted Sat, 31 December 2022 at 8:16 AM
No possible, ATM. Hopefully that will change with P13.
RedPhantom posted Sat, 31 December 2022 at 9:29 AM Site Admin
While it's not possible to make that bigger, the progressive mode under firefly render has the same results. I know it's not as convenient since it doesn't updated automatically and it's not on the screen at all times.
phil_lawson posted Sat, 31 December 2022 at 9:33 AM
Can the latest Poser version do it? I'm looking for excuses to upgrade.
hborre posted Sat, 31 December 2022 at 10:09 AM
R_Hatch posted Sat, 31 December 2022 at 9:59 PM
Brian romero actually said the raytrace preview in Poser 13 will be resizable and support Cycles.
Source: https://www.posersoftware.com/article/561/knock-yourself-out-poser
phil_lawson posted Sun, 01 January 2023 at 3:37 PM
That's it then! A good enough reason to finally upgrade. I'd have had to do it anyway if/when Windows follows OSX and stops supporting 32 bit apps.
Thanks.
hborre posted Sun, 01 January 2023 at 4:12 PM
The Raytrace preview does currently support Cycles but there are some situations that it completely doesn't render right. Also, the preview is affected by the Render setting. If you prematurely set your pixel values too high it will slow down tremendously when rendering.
phil_lawson posted Sun, 01 January 2023 at 6:00 PM
HEH, that probably explains why, when I'm trying to create a complex scene with a lot of props and try to refresh the raytrace preview Poser just goes away!
