Forum: Blender
Subject: Looking for an older version of Blender
EClark1894 opened this issue on Jan 12, 2023 ยท 30 posts
EClark1894 posted Thu, 12 January 2023 at 7:53 PM
I' m trying to find an older version of Blender, probably something between 2.7 and 2.79. My current computer can run Blender, but not with out "artifacts". I can' figure out how to get rid of those artifacts, so I thought I'd stick with an older version, so I can get back in practice. Any help would be greatly appreciated.
hborre posted Thu, 12 January 2023 at 8:16 PM
You should be able to download it from here.
Lobo3433 posted Thu, 12 January 2023 at 9:25 PM Online Now! Forum Moderator
You can download all older versions of Blender from this link   https://www.blender.org/download/previous-versions/
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Store
My Free Stuff
Facebook
Twitter
Renderosity Blender 3D Facebook Page
EClark1894 posted Fri, 13 January 2023 at 12:34 PM
Thanks guys. That helps tons. Of course, I don't have any files anymore, so I'll be starting from scratch.
Miss B posted Fri, 13 January 2023 at 3:14 PM
EClark1894 posted at 12:34 PM Fri, 13 January 2023 - #4453825
I'd like to make a suggestion Earl, whether you go with 2.7 or 2.79 (my recommendation), download a "zip" file version of  Blender.
Blender isn't really "installed".  You just set up a folder with everything that's contained in the "zip" file, and you're ready to go.
I don't know if this is true on a Linux or Mach computer.
_______________
Butterfly Dezignz
EClark1894 posted Fri, 13 January 2023 at 4:08 PM
Thanks, Miss B. I went with  2,79b to download.
EClark1894 posted Mon, 16 January 2023 at 7:29 PM
Well, I finally got back into Blender today, version 2.79b, but then I discovered that I'd been out of practice for so long, I've forgotten how to do anything except manipulate a few vertices.
EClark1894 posted Mon, 16 January 2023 at 9:08 PM
Well, I found out my mouse wheel is broken, so I'll have to get a new one to turn the Blender cameras.
EClark1894 posted Thu, 19 January 2023 at 5:56 PM
Well, I got my mouse wheel back today, but now I have to re-learn Blender all over again.
EClark1894 posted Tue, 24 January 2023 at 6:48 PM
Hey guys, I need some help. Some of it's coming back to me, but I've been away for so long, it's amazing how much I've forgotten in Blender. How do I select several vertices at once. I know I can select the one after another, but one at a time, but how do I select several at once.
RedPhantom posted Wed, 25 January 2023 at 6:53 AM Online Now! Site Admin
There are several ways to do this. You can hold down the alt while selecting to select a loop. You can select 1 and then hold down the ctrl while selecting another to select all that's in between. You can hit the b for box select and then drag a box over those you want to select or you and hit c for circle select and then drag the circle to "paint" the over the vertices you want to be selected. and hitting A will toggle between selecting all or none.
EClark1894 posted Wed, 25 January 2023 at 10:56 AM
Thanks, RP. The Box and circle select were the only ones I could get working, but they should be fine.
EClark1894 posted Sat, 28 January 2023 at 12:21 PM
Crap! Now I can't remember how to import a reference photo into Blender 2.79b.
RedPhantom posted Sat, 28 January 2023 at 2:32 PM Online Now! Site Admin
shift A and choose empty>image in the empty's properties add an image
EClark1894 posted Sat, 28 January 2023 at 3:24 PM
RedPhantom posted at 2:32 PM Sat, 28 January 2023 - #4454811
Yeah, but how do I add the image?
RedPhantom posted Sat, 28 January 2023 at 4:23 PM Online Now! Site Admin
https://www.youtube.com/watch?v=_6Ha6Le2fOA&t=60s Try this. It might help to see it.
EClark1894 posted Sun, 29 January 2023 at 10:46 AM
Thanks again, RP. I never really learned how to used Emptys. I always just added the reference image directly into Blender. But your posting a YouTbue vide made me realize that I had forgoteen how I learned much of Blender in the first place, so I went back to basics and found a video on posting a reference image directly into Blender.
https://www.youtube.com/watch?v=mehosaTPOvI
Miss B posted Sun, 29 January 2023 at 11:20 AM
EClark1894 posted at 10:46 AM Sun, 29 January 2023 - #4454868
While checking out that video Earl, I noticed a link on the right side at YouTube for a similar video for Blender 2.79 that you might find better, since Blender 2.79 is the version you're using.
https://www.youtube.com/watch?v=hLjni-QVxXo
_______________
Butterfly Dezignz
EClark1894 posted Sun, 29 January 2023 at 12:40 PM
Miss B posted at 11:20 AM Sun, 29 January 2023 - #4454871
Thanks, Miss B. I'll look it up. In the meantime. I have gotten at least a rough draft of the ski boot I wanted to make. I need to remember how I made squares into circles next.
EClark1894 posted Sun, 29 January 2023 at 8:06 PM
Well, I'm getting there. Now I just have to remember how to use the shrinkwrap modifier.
EClark1894 posted Sun, 29 January 2023 at 9:29 PM
I think this is pretty good considering I'm relearning as I go.
EClark1894 posted Mon, 30 January 2023 at 5:19 PM
Okay, I've been stopped cold because I can't seem to follow how to mirror an object. The main problem seems to be repositioning the origin point.
EClark1894 posted Mon, 30 January 2023 at 5:49 PM
Ooops looks like I spoke too soon. Now I just have to make it look like a ski boot.
hborre posted Mon, 30 January 2023 at 5:56 PM
Very thick and rigid.
With lots of buckles.
And thick soles.
EClark1894 posted Mon, 30 January 2023 at 6:20 PM
hborre posted at 5:56 PM Mon, 30 January 2023 - #4455012
And thick soles.
I can add a solidify modifier to thicken it up. Question I have to figure out is if the buckles are attached before or after I add the modifier. Also, I think my ankles need to be wider and the boot less tapered.
hborre posted Mon, 30 January 2023 at 6:55 PM
EClark1894 posted at 6:20 PM Mon, 30 January 2023 - #4455024
And thick soles.
Yep.  As I  posted, they are clunky and not very flexible to wear.  You can Google for images just to get a general idea of what they look like.
Warlock279 posted Tue, 31 January 2023 at 11:53 PM
Yeah, the overall shape is bit too "form-fitting" for ski boots, can certainly bulk up the ankle/foot for more of that ski-boot look.
So far as when to add the buckles, it shouldn't matter, treat them as their own object/part [just like the real thing] so they can have their own set of modifiers. I would probably add the solidify modifier to the boot, but not "apply" it until later, that way the base geometry [the fewer points there are to tweak at any point, the better] can be tweaked through-out the process of making the buckles and anything else. Save any "destructive" or "one-way" actions like applying modifiers for as late in the process as possible.
Core i7 950@3.02GHz | 12GB Corsair Dominator Ram@1600mHz | 2GB Geforce GTX 660
Lightwave | Blender | Marmoset | GIMP | Krita
EClark1894 posted Wed, 01 February 2023 at 6:50 PM
Okay, I'll take hints for what I'm doing wrong. Nothing is sticking out from the boot mesh, but I'm still getting these protrusions from the front  toe of the boot when I apply modifiers, especially, solidify and increase the thickness.
EClark1894 posted Thu, 02 February 2023 at 5:47 PM
Going nuts today. My monitor went on the fritz and I've had to use an old 15 inch hp monitor that for the life of me I can't remember how to scale or adjust the contrast on so I can see everything.
EClark1894 posted Sat, 04 February 2023 at 11:52 AM
Okay, got a new monitor today. Back to the Blender salt mines!
