chud opened this issue on Jan 13, 2023 ยท 11 posts
chud posted Fri, 13 January 2023 at 2:11 AM
Is there a way to turn off all lights in Poser 11?
SamTherapy posted Fri, 13 January 2023 at 4:56 AM
Delete them all - there's a script - or simply switch their values to zero.
RedPhantom posted Fri, 13 January 2023 at 7:22 AM Site Admin
Or on the properties tab, uncheck the on switch.
hborre posted Fri, 13 January 2023 at 9:24 AM
People, read the question! The OP wants to turn off ALL lights in the scene at once. Follow the Path in the screencap below:
Once the XLC Panel opens, right-click Light on the banner (highlighted) which will open the Parameters window, and there you will find the context field for turning on/off lights (highlighted).
This is how it's done in P11.
SamTherapy posted Fri, 13 January 2023 at 12:23 PM
I did read the question. Can't see where it says "at once", though. Either way I suggested - and the others - work.
hborre posted Fri, 13 January 2023 at 1:16 PM
It's a matter of implication but you are right, the OP was not explicitly clear about how to turn off the lights. All should be good now; all the bases have been covered.
chud posted Fri, 13 January 2023 at 6:28 PM
Thank you. My apologies for not being clearer. :)
NikKelly posted Sun, 15 January 2023 at 11:27 AM
That's a useful trick, especially when you're trying to set a scene with 'luminous' stuff, as super-ambient and/or Cycles' emission.
willyb53 posted Fri, 12 May 2023 at 8:54 AM
One other way :D
https://sharecg.com/v/57963/gallery/8/Script/Light-Toggle
Designed so you could set up working lights, toggle them off and set up the render lights, and then toggle back and forth as needed
Bill
People that know everything by definition can not learn anything
chud posted Sat, 13 May 2023 at 12:14 AM
Thanks willyb! That's precisely what I needed.
ghostship2 posted Sat, 13 May 2023 at 1:52 PM
my free light set here at Renderosity includes a preset that deletes all lights and one that loads three global lights that do not illuminate when rendered for those times you are using an HDRI or glowing objects.
https://www.renderosity.com/freestuff/items/86815/studio-lights-for-poser-12-and-poser-11
