Chrom93 opened this issue on Jan 25, 2023 ยท 7 posts
Chrom93 posted Wed, 25 January 2023 at 8:55 AM
hborre posted Wed, 25 January 2023 at 9:51 AM
Without knowing what your scene(s) contain and how large is/are the file(s), it's hard to tell. Bad render settings? Is there any other information that you can provide?
nerd posted Wed, 25 January 2023 at 12:32 PM Forum Moderator
The most likely culprit is bag geometry. There are combinations of geometry that break the subdivision in Poser. An example of this is something called collinear facets. Another that can cause issues is non-manifold surfaces. Poser attempts to detect these and avoid attempting to render them but the possibilities of weird geometry are endless.
The work around is to use the older version of Poser (Yes you can have more than one major version installed on your computer) and remove items from the scene until it will load properly. That at least you'll know what prop or figure is causing problems.
Chrom93 posted Wed, 25 January 2023 at 1:33 PM
Thank you,
I will check this out.
NikKelly posted Thu, 02 February 2023 at 1:09 PM
'Crash' crash, or renders black ??
Latter may be due to scene and/or texture complexity. IMHO, Poser_11's 'garbage collection' can get 'maxed-out' if you do a lot of texture changing, especially 2k, 4k, 8k super-detailed textures. Save PZ3, close and re-start Poser usually helps. If necessary, down-size mega-textures using eg free Irfan View.
Don't know about Firefly, but I also tackle persistent 'renders-black' failures in Superfly by reducing my 'vols & buckets' from 1024 by binary stages to 64. At that point, probably faster to switch from my overloaded GPU cards to CPU-only, or send job to networked 'Box'...
Chrom93 posted Thu, 02 February 2023 at 11:30 PM
It is s real crash crashs- poser shut down during renderring while picking the textures. So your point about textures seems to be correct. Simply saving does not always work , but I can rebuild the old scenes with newer poser without problems. Just takes its time. Well I hope the upcoming Poser will do better.
Thanks again
Y-Phil posted Fri, 03 February 2023 at 2:41 AM
Have you tried to launch Poser and instead of opening an old Poser file to import it?
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
