RAGraphicDesign opened this issue on Jan 27, 2023 ยท 9 posts
RAGraphicDesign posted Fri, 27 January 2023 at 9:39 AM
Hello everyone !
Since yesterday I have a problem in Poser 11 Pro that has never happened to me before...Did I do or touch something that I shouldn't have touched? What happens to me is that when I have the scene with the "Main Camera" set and I start the render what I get is a black rectangle. While if I opt for the "Posing Camera" I can have the normal render. Anyone have any ideas? Thanks for your help.
hborre posted Fri, 27 January 2023 at 10:27 AM
Did you reset the Main Camera to its default settings?
feecozen posted Fri, 27 January 2023 at 12:32 PM
Where is the Main Camera positioned? This can happen if an object, like a visible ground plan or a wall, is between the Main Camera and the rest of the scene.
RAGraphicDesign posted Fri, 27 January 2023 at 1:43 PM
Thank you all ! The funny thing is that I had used the walls of this room before and I absolutely don't remember moving one of the walls...I'm definitely getting old..
If you want to see the reduced render you can see it HERE. Despite the wrong "Chamber" it didn't come out bad...
Y-Phil posted Fri, 27 January 2023 at 4:13 PM
Here is a little trick that can help to move the main camera correctly, or at least to retrieve it..
1. Switch to the top camera
2. In the Hierarchy window, activate the display of the cams
3. Select the main cam and make it visible
4. Go to the Menu: Display > Object Style, select one of the possibilities, example:
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
RAGraphicDesign posted Sat, 28 January 2023 at 3:21 AM
Y-Phil posted Sat, 28 January 2023 at 7:48 AM
RAGraphicDesign posted at 3:21 AM Sat, 28 January 2023 - #4454786
You're welcomeThanks Y-Phil, advice much appreciated:)
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
NikKelly posted Thu, 02 February 2023 at 12:56 PM
Yay !! Neat !!!
I often find some juggling of camera position plus camera's 'hither' setting allows sufficient suppression of 'photo-bomb' pillars, walls etc...
It's when entire scene renders black that the real head-scratching begins...
Y-Phil posted Fri, 03 February 2023 at 2:43 AM
NikKelly posted at 12:56 PM Thu, 2 February 2023 - #4455219
Indeed, we've all encountered such situations...Yay !! Neat !!!
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Nas 10TB
