cloudwatcher opened this issue on Feb 19, 2023 ยท 5 posts
cloudwatcher posted Sun, 19 February 2023 at 4:20 PM
Hi all -
I'm having a weird problem with opening Hull Breach from Coflek Gnorg in DAZ Studio. This set has 4 pieces, an airlock and three hallways.
When I add the Airlock I can see the door (yellow) part, but the rest seems to be missing.
When I add any of the hall segments, the figure appears in my scene tab, but there's no geometry there. If I go into the Geometry Editor and select all, nothing appears. Literally zero polygons. The Face Groups and Surfaces are also empty in the Geometry Editor tool options pane.
Suspected file corruption so I re-downloaded and replaced all files. Same story.
I looked at at the CR2 file in a text editor, all the paths look correct. If I go to the Geometries folder and open the OBJ files with Windows' 3D viewer, it looks fine. I can also import the OBJ into DAZ and it appears, although it is miniscule.
I also have the Valkyrie space ship from the same vendor and that loads without a problem. I haven't seen this with any of my other Poser-format products either.
I'm on Studio 4.16.0.3 (64 bit)
The log file tells me it's removing face groups but not why:
2023-02-19 17:13:19.249 Importing File...
2023-02-19 17:13:19.250 Importing Curved Segment.cr2 ...
2023-02-19 17:13:19.318 Reading: Curved Segment.obj
2023-02-19 17:13:19.809 PZ3Importer: Removing face group wall_4 no associated node.
2023-02-19 17:13:19.819 PZ3Importer: Removing face group wall_3 no associated node.
2023-02-19 17:13:19.827 PZ3Importer: Removing face group wall_2 no associated node.
2023-02-19 17:13:19.837 PZ3Importer: Removing face group wall_1 no associated node.
2023-02-19 17:13:19.844 PZ3Importer: Removing face group wall_5 no associated node.
2023-02-19 17:13:19.853 PZ3Importer: Removing face group wall_8 no associated node.
2023-02-19 17:13:19.861 PZ3Importer: Removing face group wall_7 no associated node.
2023-02-19 17:13:19.868 PZ3Importer: Removing face group wall_6 no associated node.
2023-02-19 17:13:19.874 PZ3Importer: Removing face group curved_base no associated node.
2023-02-19 17:13:19.896 Imported file in: 646.661 ms
2023-02-19 17:13:19.908 Imported file: D:\DAZ3D\My DAZ 3D Library\Runtime\Libraries\Character\[Sets]\Coflek Gnorg\Hull Breach\Curved Segment.cr2
2023-02-19 17:13:19.908 Updating Scene...
2023-02-19 17:13:19.989 Imported: 0m 0.822s - D:/DAZ3D/My DAZ 3D Library/Runtime/Libraries/Character/[Sets]/Coflek Gnorg/Hull Breach/Curved Segment.cr2
2023-02-19 17:13:34.679 WARNING: ..\..\..\..\..\src\sdksource\shapes\dzfacetmesh.cpp(8026): Index out of range in DzFacetMesh::getMaterialGroup()
