donload opened this issue on Mar 04, 2023 ยท 5 posts
donload posted Sat, 04 March 2023 at 9:24 AM
I'm using Poser from more than 20 years and I never had this problem.
I can select multiple keyframes but I can't paste the group as I wish. I only get a single keyframe when I paste.
What's wrong with Poser 11?
I have bougth Poser 11 few years ago and never really use animation panel (as I did with 7 and 9 so often).
Can I have missed something ? A parameter locked ?
I want to do a animation test with a kind of perpetual cycle but I can't find how to copy each cycle in P. 11.
If someone have an idea, this will be appreciated.
Thanks.
An Old user.
donload posted Sat, 04 March 2023 at 11:56 AM
I answering me for now : I can use Ctrl+C to copy and past multiple key frame but the Edit/Copy Edit/Paste not working att all for more than one frame. I don't know why.
D.Ludvik
nerd posted Sat, 04 March 2023 at 2:56 PM Forum Moderator
This is a design limitation of the Animation palette. If you pick copy off the Edit menu it copies the current body part, not the entire frame. So, just the head or hip or whatever is selected in the pose window. The keyboard method is the only way to copy multiple frames. But, there's another keyboard trick which is much faster for making loops like walk cycles ...
Select the range of keys you want to duplicate. Then [Alt]+Drag them to the new location on the palette. Drop them where you want to loop your animation. Copied and pasted in one action.
donload posted Sun, 05 March 2023 at 3:37 AM
Thanks for the trick, I really appreciate your help. That's will be more easy than copy/paste.
D.L.
Y-Phil posted Sun, 05 March 2023 at 7:12 AM
Wow. nice trick!
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟ Nas 10TB
๐ฟ Poser 13 and soon 14 โค๏ธ
